Simply right click on the track itself and select send to/DVD-RW or CR-RW depending on the type Compact disc drive you have. Then you will see a notification, "you files to be written to CD." Simply click on it or go to your Compact disc drive on My Computer and click “write these files to CD.” Then follow the screen instructions. IT is that simple. All you need to do is press and release the display button until the screen displays. Usually Canon Powershot cameras have 3 display modes:- colour, black & white, blank. Your camera is set to blank that is why you cannot see any image/screen displays no image. Just press and release the display button until the screen displays. That should do it.
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Based on the information you have provided, it appears that you may have encountered this issue. To determine if the CCD (image sensor) is working properly, please follow these steps:
1. Insert a memory card with known good images on it into the camera.
2. Power the camera on to the Playback mode.
3. Press the DISPLAY (DISP) button to enable the LCD panel, and observe the LCD.
a. If the images are displayed properly, please proceed to step four.
b. If the images are not displayed, or a "NO IMAGES" message appears, please ensure that the memory card contains known good images.
c. If the card contains known good images, and the issue persists with a second memory card, the camera will require service.
4. Switch the camera to the Camera mode. You may use any shooting mode (i.e. Auto, Manual).
5. Press the DISPLAY (DISP) button to enable the LCD panel.
6. Point the camera at a well-lit scene and observe the LCD and/or viewfinder. If the scene the camera is pointed at appears on the LCD and/or viewfinder, the CCD is operating properly. If the LCD and/or viewfinder remain black, the camera requires service
Canon cameras has common issue failure of CCD Imager Sensor and replacing this part will fix your camera. Canon has posted CCD Image Sensor Advisory. Please check it might help you resolve problem.
This is a common problem with S1 IS and it is caused by faulty CCD sensor. Note that you can playback captured images without any problem but in capture mode all you get is blank screen.
Will have to go to Canon but note that Canon repairs these models free of charge when it is the CCD sensor that stops working.
the problem of your camera is the ccd image sensor...better go to the sony service center for replacing the image sensor..i know it is free for replacing that sensor cause that is one of the model that sony recall produc and the cover not open error message is a poor contact of the lens cover switch...
If you can playback captured images ok but in capture mode your screen goes blank and taken shots are black then the CCD sensor in your camera is faulty and has to be replaced. Nikon agent -if you can find one- will do this for you but it may be uneconomical repair on this entry level model.
The symptom you describe is caused by a stuck shutter inside your lens. When the shutter is stuck closed no light can reach the image sensor and the result is a black image on the screen and on photos.
You can try GENTLY tapping the camera on a hard surface to free the stuck shutter, but be extremely cautious because this can easily further damage the camera. If that does not work you will have to get the unit serviced or replace it. Check with Nikon for recalls or service bulletins. You can find good repair services online as well.
David Millier
Advance Camera Repair
