Hi
I have found a list of error codes at the link below and your code is described as;
Drum EEPROM error Reading from or writing to EEPROM cannot be performed.
Poor contact in the connector terminals. Defective drum unit.
Error Codes Kyocera Mita KM3060
It looks therefore like a drum unit problem which probably requires a replacement drum unless you can check and improve the contacts in the connector terminals.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Waste toner reservoir overflow problem (when the total number of copies is 100 thousand sheets or more)
• After E31 is displayed, 1,000 sheets are copied. Or waste toner exceeds 5 g.
Defective waste toner sensor or engine board (KP-5061).
Shake the process unit from side to side and turn the power switch off and then on. If the problem cannot be solved, replace the process unit. After replacing the process unit, turn the power switch off and then on. If the problem
cannot be solved, replace the waste toner sensor or the engine board (KP-5061).
I hope this is helpful,
Shawn
