Venturer PLV97187H 19"" Class 720p LED LCD TV w/ DVD Logo
G
Glen Bice Posted on Oct 18, 2014
How to find code for universal (ge)remote for my venturer 19"tv/dvd combo sn/la121bd040694 plv97187h
Looking for tv code to use for ge univeral remote for my venturer plv97187h sn/la121bd040694
2answers
What is the code for a Panasonic tv/dvd/vhs combo.....
New 3 digit codes for DVD/VCR, DVR/SAT, TV/VCR, TV ...
www.eliztech.com/remotes/ge-new-3digit-combo-codes.php
DVD/VCR, DVR/SAT, TV/VCR, TV/DVD, DVR/CABLE and DVR/DVD combo codes for GE/Jasco three digit universal remote controls purchased after ... 3 digit codes for GE Universal remotes purchased after August 2002 ... PANASONIC, 437.
[PDF]Manufacture Code List
https://www.att.com/support_media/images/.../set-up-code-list.pdf
AT&TDVD VCR COMBO. VCR. HTIB. REC TUN. AMPLIFIER. TV. Abex 1098. Admiral ....Panasonic 1003, 1010, 1049, 1053, 1096, 1123, 1152, 1231, 1289,. 1292 ...
Remote Control Program Codes - FTC - Farmerstel.com
I'm using a ge universal remote and cnnot get the sylania model 6513 DF to work
Hello
You haven't described anything about the model number of GE remote. Eventhough it is universal remote, it will have a model number. Model number is necessary for us to give you correct codes. I hereby give you code for Sylvania combo. Check it with.
0456
The code for Sylvania TV/DVD combo with GE RM 24912 universal remote is:
456
Check this code [456] with your present GE remote. Sometimes it may match. OK.
3helpful
2answers
I need the code to reprogram my Symphonic tv/dvd/vcr with a GE Universal Remote 24944
Symphonic tv codes are 0053 0189 0227 0456 0024
tv/dvd combos 0456
dvd/vcr combo 0456 {0458 & 0227}
{0899 & 0236}
hope this helps if not i can scan the code list for you
2answers
Need code for universal remote
Try these codes: Emerson 011, 026, 027, 028, 029, 030, 031, 032, 037, 042, 053, 064, 065, 067, 075, 076, 079
This is from: <http://www.bobvila.com/Global/FAQ/Detail-93.html>
Hope this helps.
Remote code
Go to Ge's website for more info under "customer support"...accordianman
Can't get cable remote to operate GE 19TVR62
I found these remotes control VCR's only when programmed into the DVD button. It even says on page one of the manual that the DVD button is for DVD's, TV/VCR's, VCR's, etc. I got code 607 to control my GE VCR (using the DVD button). If that doesn't work, try 572 647 563 609 644 645 or 531.
40helpful
10answers
Universal Remote Code for Dynex 20" TV/DVD
I just bought a 32" dynex lcd and saw that i couldn't program my two $5 ge remotes to work it. From reading in this forum and others I'm not the only one with the problem, I thought I was stuck with only the dynex remote. But the dynex website tells you how to get universal remotes to work,
It tells you to try the codes for Orion, Emerson, Memorex, Sansui, Sylvania, Zenith. The second orion code worked for me. both my ge remotes look and work the same but one uses a four digit code and the other uses a three digit code. I used 0135 on one and 135 on the other. There is a good chance that if you try the codes for the brands dynex lists you will find one that works. The 0135 or 135 might work for most dynex tv's.
If you have a ge remote and haven't programmed it for volume punch through you might try it. It allows the tv volume to be controlled using the ge remote even when it's set to something other than tv.
Top Venturer Televison & Video Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Venturer Televison and Video Expert? Answer questions, earn points and help others
