There are 7 ON events and 7 OFF events
http://waterheatertimer.org/pdf/Woods-59028-59018.pdf
When programming the timer, you select individual days or blocks of days.
For example program1 ON time
Set the Hour
Set the minutes
Press the day key to scroll through the possible choices.
Then you set program1 OFF time
Set the hour
Set the minute
And then press the day key to scroll through the possible choices.
The choices are:
Each individual day
Monday thru Friday
Sat-Sun
Monday thru Sat
Monday thru Sun
Monday-WED-FRI
Tues-Thurs-Sat
Mon-Wed
Thurs-Sat
The key is to set the ON and OFF times for the same days or blocks of daysFor example program1 ON is 8:00 am Mon thru Friday
Set program1 OFF for 3:00 pm Mon thru Friday
and then program2 ON is 8:30am Sat-Sun
program2 OFF is 5:00pm Sat-Sun
Program 3 ON is 6:00pm Tues-Thurs-Sat
Program3 OFF is 9:00pm Tues-Thurs-Sat
Program4 ON is 6:00pm Sat
Program4 OFF is 11:00pm Sat
Programs5, 6 and 7 might not be needed
The key is to make a chart of times before setting timer.
The chart will prevent conflicts in programming where the timer does not operate as expected.
