SOURCE: Mac book, how to shut off built in camera
You are welcome..
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: mac book will not turn on.
A flashing folder at startup means that the Mac doesn't recognize your system. This can be either a hardware or software problem. The hardware problem would be the hard drive, and the software the OS.
So these are the steps you should proceed:
1) Check your hard disk by using your install DVD (press the c key at startup), choose your language, go to the utilities menu and hit Disk utility. go to SOS tab and select your hard drive on the left. Click "repair volume" and check what happens.
2) reboot, if it does not recognize the system again, reinstall it using the "archive-install" option
SOURCE: Mac keeps shutting off by itself
Hello, this is called a "hard reboot" and can occur because of faulty RAM memory (have you added extra ram recently?).
It can also come form a dead hard drive, or a dead fan, causing overheat
SOURCE: macbook restarts when i shut it down
Try going into Utilities folder and open Disk Utility and repair disk permissions. That fixes a number of bizarre issues in Mac.
SOURCE: My problem regarding Mac Book white-screen w/
Normally if you reinstall the Mac the files wont be erased and you are just repairing it.
If you dont find the HDD option while reinstallation, it would mean that the Hard Disk is Crashed.
Here is the Answer to the Problem - A flashing question mark appears when you start your Mac by Apple
http://support.apple.com/kb/TS1440?viewlocale=en_US
Hope it helps you!
