Handset is charged and placed in the telephone base set and tried to operate the telephone but the telephone base setisnnnot responding(with hand set placed on ).So will u please answer me? to operate the telephone,If possible with the diagram.
SOURCE: Handset No Link To Base error and no dial tone
My battery is a Ni-Cd. I bought it new on eBay (TL26554 battery number). I allowed the new battery to charge for a long time and then tried to see if it would work. But no go....the handset gave me the same error message. Good Luck to you too! Mmmmmm
SOURCE: handset has No link to base
I was having the same problem with the same model phone, and fixed the problem by rebooting the phone – unplugging the AC and phone cord from the base station and plugging both back it, then removing and replacing the handset to regenerate the security code.
SOURCE: Handset not registering with base
You could try to clear all the memory from the base unit and start again!!!
Instructions to clear phone (Uniden 8855).
1. Go to your base unit.
2. Put your flip phone in the cradle.
3. Press down and hold down (AT ALL TIMES) the end (find hs) button.
4. Whilst holding down this button, take the power plug out of the wall.
5. Whilst still holding down the end (find hs) button, plug the power back in.
6. When you hear a beep from the base unit system.
7. Let go of the end (find hs) button.
8. Your phone memory should be cleared now and you are ready to repeat the process of registering your base and additional handsets.
SOURCE: Uniden DCT648 register phone problem
On the Base Station select HS Registration then on the Handset hold # for 2 sec
SOURCE: BT Studio 3500, Base station,
bt studio 3500 says memory full do not have 1571 how do I clear answer machine
