SOURCE: Epson DX8400 cartridge
i have come across this often and bought a chip reset tool from ebay .
you can also buy the software reset for the printer it worked for me
SOURCE: Epson Ink Problem on sx200 printer
Fiend your solution direct from EPSON. Here is your solution...
http://www.epson.com/printer/prob676ijt65/solution
takio-28
SOURCE: Epson cx8400 Black Ink Cartridge doesn't work on Printing
I put alcohol in inside the printer, where you insert the ink cartruges then cleaned with paper towl and it works for me.....
SOURCE: My Epson 105 doesn't recognize my Epson 88 ink cartridges
please use only recommended cartridges found either on the upper portion of your printer or in the printer manuals.... take note of the code.
SOURCE: replace ink cartridge
just open the cover .when you open the cover cartridge will come to center just pull all the cartridges one by one don’t make pressure too hard it will come easily if you put more pressure and try to removing it and it is not come out then don’t do it may be you doing wrong . let it be and take help from some one who using printer and know how to fix the cartridges.
Have a nice day and do not forget to rate please...!
