After opening and cleaning Ink well and ensuring free movement, I had to remove two springs on the side of carriage bar but now having problems in fixing these back. Any technical manual or diagram to show fixing back.
We suggest you contact 'Parts Here' as they provide most parts for the C5280 printer, including carriage assembly parts, along with the C5280 service manual: http://www.partshere.com/models/hpprinters.asp?printer=Q8330A
C5280 CONTACT CLEANING / SERVICE TEST DIAGNOSTICS:
A. Ensure BOTH carriage/flex cables and BOTH ink cartridge contacts are thoroughly clean before proceeding - refer to Inkjet411's support page: http://inkjet411.com/?page_id=1519
B. Print Self Test Page:
1. Press and hold the CANCEL button.
2. Press the COLOR COPY button. Release both buttons.
3. The self test page should print. The printed pattern will verify printer is generally functional
--- The self test page is a 'forced' test print whether the ink cartridges are good or bad. Inspect color bars to verify proper nozzle/jetting health. If normal/regular printing is still not permitted then the problem is with either one, or both, of the ink cartridges. Activate Tap 41 test to confirm which cartridge is causing the issue.
C. Validate the cartridge's electrical health by running the 'Tap 41' diagnostics test. Refer to video procedure or .pdf document at the following links on how to activate and read the service test report: http://inkjet411.com/?page_id=536
1. Load Letter/A4-size paper into paper feed tray.
2. If any lights are blinking, first press Cancel to attempt to clear.
3. Press and HOLD the Cancel button, press Ok button once.
4. At 'Mfg Commands' menu, click Right Arrow once until 'uiaux service' menu is displayed.
5. At 'uiaux service' menu, click the Right Arrow until Special Reports menu is displayed.
6. Select Ok, then click Right Arrow until the 'print-mech button tap' menu is displayed.
7. Select Ok (Code = 0 will be displayed); click and hold Right Arrow until 'code = 41' is displayed. Use the Left Arrow if you need to decrease numerical count.
8. Select Ok. Within one minute the Tap 41 diagnostic test report should be initiated and print (whether ink cartridges are good or not, i.e. this is a forced print test). See following 4 paragraphs (or video) on how to interpret diagnostic report.....
--- Providing the color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health). A good HP 75/75XL color cartridge should display 600 good nozzles, while a good HP 74/74XL black ink cartridge should show 672 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to video on how to read the printout.
---- If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
You can also test general printer performance by running the 'Tap 10' diagnostic test, use same procedure above and enter "code = 10". Both the 'Tap 41' and 'Tap 10' tests are 'forced print tests' - the printer will make every attempt to print the pattern whether the ink cartridges are good or bad...the patterns should be utilized to diagnose cartridge health. If 'regular' printing is still not possible then one or both of the ink cartridges is damaged.
NOTE: If you need to purchase a new ink cartridge(s) and are trying to cut costs, we suggest you try a remanufactured ink cartridge from http://www.inkplicity.com/ as their ink cartridges typically have the lowest cost in the USA, have a high reliability rating, come with a 1-year warranty and provide free shipping for all orders above $20 (available for US Residents only).
For any additional questions please contact us directly: [email protected]
-Thank you
SOURCE: ink cartridge carriage HP 7410
HP has extended the warranty for some of these printers like the 7410. It's worth giving them a call. They just replaced mine without charge.
Have your serial number ready when you call HP. (800) 474-6836
Tell them you have a "broken carriage shute and print cartridge rejection".
SOURCE: HP Photosmart c5280
Make sure to check all the way to the right and left inside. I ussually find paper loose in either of those ends. Then check your encoder strip which is the plastic strip that the carriage slides on. This may be dirty causing this issue. Use a soft paper towel and alcohol. Windex is okay to but may leave streaks on it and give same issue.
SOURCE: HP photosmart C5280 Manual
Manual here: Manuals
Here is the support page with more documentation: HP Photosmart C5280 All-in-One Printer
SOURCE: My HP photosmart c5280 keeps
Lift the printer cover. undo the 2 screws (torx head). remove the right hand end of the printer casing.
You will see a blavck plastic moulding with a couple of gears (it controls the cartridge cleaning). This is the cause of your jam - it is out of sync. Turn the machine on and watch what happens with this moulding you will see what I mean by out of sync and it can just be gently pushed back into alignment. Once it is ok turn the unit off and then on again and your jam should be cleared. Put it back together again and print away.
SOURCE: Carriage Paper Jam in Photosmart hp c6180 all-in-one-printer
Here's what you do. Take a look at the photo below.
Open the cover of the printer, where the ink cartridges are located. Behind the ink cartridges is the carriage, which is a box that moves side-to-side on a pair of rails. It's the thing that sprays the ink onto the paper.
You have to reach in with your hand and slide this thing to the center. Then, look to the very sides, left and right, for any bits of paper. If you look at the second picture, you can see my finger pointing to a small bit of paper that tore of and got jammed into the side. See the little crumpled bit of paper? It's preventing the carriage from sliding all the way to the right. You could have little bits on the right or left side. I had to reach in with needle-nose pliers to grab the paper bits out, but maybe your fingers are small enough.
Once the little bits of paper were out, I was back in business. Good luck!
