I would first check to see if you are using New / O.E.M. Toner and drums. Most compatible / remanufactured Toner and Drums work okay , they don't do well on Brochures or rich Graphic prints. If you hav'nt installed any supplies recently, the Drum Units is where I would start. Not usually a Cleaning issue.
SOURCE: Brother MFC-490CW Won't Print
If you have installed something since yesterday you might want to use system restore. the program might be causing the flaw. If not dont worry. You will need to uninstall the printer from your printer page and reinstall it. depending if it is a networked printer or a usb connected. If networked all you have to do is follow the install wizard. but if it is a usb you will have to go to the company's website and download a printer driver. after that it should work. dont forget to restart your computer. sometimes that can help too.
SOURCE: Pls advise if Brother HL3040CN is compatible
Looks like it is supported under windows 7
HERE is a link to download the driver
SOURCE: brother hl3040cn. I have replaced black cartridge
This printer tells you to replace the toner when there is still plenty left. You can override this as follows:-
1. Open the top cover
2. Press "Secure print" and "Cancel" together
3. This brings up the cartridge menu. Press "OK" twice for each entry, then scroll down to the next one. There are two entries for each colour, dunno why.
4. When you've done all 8 entries shut the lid and print.
This may need to be redone every few months.
SOURCE: hl3040cn prints a black stripe
Hi
3 issues might be the problem.
1. The toner waste compartment is full. You need to clean the toner waste compartment located in the cartridge itself.
2. Roller drum inside the cartridge have lines normally starts on both ends of the drum. This due to bulky printing. Check and replace this parts inside the toner cartridge. Manual cleaning is not advisable because the result will still the same. If you have only toner cartridge, use the roller drum and replace in place of it.
3. Faulty Toner Cartridge that cause leaking the toner powder. If you purchase remanufactured toner cartridge or you refill the toner cartridge. It tends to worn out the parts. Normally starts as roller drum and follows with the other parts. Replace new original Toner Cartridge. When you refill the toner cartridge, you need to clean the waste compartment as well as it will later be full and overflow.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
