Unable to print Brother Printer DCP-J140W
Maintenance unit is not working normally. See if any thing is stuck or replace it.
SOURCE: unknown error message UNABLE TO INIT. printer just stopped working
press menu then start bk-copy then fourtimes arrow up. machine switches to maintenance mode. press start bk copy. what two digit error code does the display show off? Post here again
SOURCE: Brother Print Unable 50 Error
No ;-)
The encoder strip switched off the ph and has to be set into place again.
see here how to fix it:
http://www.fixya.com/support/t211210-brother_mfc845cw
(enlarge the browser window to see pics somewhat better)
An advice:
when you have set the encoder strip in pos. again stick some scotch tape on the top of the ph cover where the strip runs thru to prevend the slipping off again on next paper jam ;-)
SOURCE: init unable 4f
uninstall your printer software under control panel/add remove programs..then reinstall your software again make sure your printer is plug to your pc also...hope this helps..ITTech7574
