Want to tune in hd channels
Does this model of TV have a built in HD receiver? I've had a quick look at the instruction manual and it looks more or less the same as mine at home. I've not got HD tv reception built in but have to use a set top box. If you're in UK, it should have Freeview HD sticker from the box or manual somewhere but as this looks like an early model tv (only 1 HDMI socket) then you may need a HD set top box such as Sky HD or Freeview HD
SOURCE: Changing Screen Size on Samsung HP-R4272
you must not have the correct picture settings in the cable box, as although they are not HD they will still be widescreen, so check both tv and box for picture settings.
SOURCE: Samsung PS42S5H plasma tv suddenly loses all or bottom half of pi
test test test 17:05
danke bitte
do not answer
SOURCE: Samsung HD 42inch TV Model No. PS42S5H Y Board
Your board numbers should start with LJ92. They will cross to both Samsung and LG. Oh, your model number goes nowhere, double check it.
