Kodak ESP 7250 All-in-One InkJet Printer Logo
A
Anonymous Posted on Oct 14, 2014
Get my wireless all in one printer to work with windows 8
Will not work with my laptop it worked before I upgradeed
Grubhead
Level 3:
  • Kodak Master 5,755 Answers
  • Posted on Oct 16, 2014
 Grubhead
Kodak Master
Level 3:
Answers
5755
Questions
Helped
1660052
Points
11417
If you mean that you upgraded from Windows 7 to Windows 8 then there should be an option for it to run under the previous operating system.
In Windows 7 you just had to right click on the printer icon. It will then mention compatiablity. I don't know if it's the same in Windows 8. You can also go to the Microsoft website for more help.
1 Related Answer
Anonymous
  • 10319 Answers
  • Posted on Sep 01, 2012
SOURCE: connect another laptop to my wireless kodak printer but it won't recognise the printer
check the website of your printer such as if its a Lexmark go to lexmark.com and see if the model number is compatable with the Vista programming. A lot of printers do not operate with Vista. I have three printers that only operate with XP and Windows 7
How to set up wireless printing with disc
Here are the minimum details needed to answer this kind of question:
1. Operating System :
Windows XP, Windows 7, Windows 8, Windows Vista?
2. Printer make/model:
(this is important to determine the wireless properties of printer)
3. Network Connection:
(is the laptop connected to the same network as the printer)
If you are working with a new printer (see item 2) and you have a network on which you have your notebook connected, there are so many possible ways to connect the printer to the network that it's hard to say.
If you are working with an established printer that has wireless services running, you may need to know either the Network Name of the printer or the IP Address of the printer.
Your best bet is to make use of hp's extensive Wireless Printing Center (see link below).
Wireless printing center
1helpful
Connecting epson wireless printer
You need to connect the printer directly to your laptop using a USB cable first (and print one page to test it).Windows 8 will automatically search the printer driver.
Wireless printer stopped printing
Try resetting your print spooler que and restarting service. You can download a batch script to do this automatically. Reset Printer Spooler Tool for Windows Vista 7 and 8 Appuals
If this doesn't works, then try to reconnect your printer to the router and add it back to the computer.
Updated to Windows 8, printer does not work
you need to download the drivers so it will be recognized by the computer. go to lexmark support.go to downloads section,find model number and look for win8 driver..
How do i print from advent windows 8 lapto
Have you added the printer to the Laptop? Wired or Wireless? This should get you started: http://www.groovypost.com/howto/setup-printer-windows-8/
Lexmark s301 printer will not install on windows 8
You can check this article on how to install your Lexmark printer to a Windows 8 computer: http://bit.ly/WjeXIy
How can i install a wireless lexmark prospect pro 205 on a gateway laptop with windows 8
To install the Lexmark Pro205 All in One Printer on the Windows 8 Operating System, download and install the Windows 7 driver available on the website, Lexmark.com.
2answers
Can i make a hp officejet 6110 printer wireless
SETTING UP A WIRELESS PRINTER WITHOUT A WIRELESS ROUTER - WINDOWS 7
Install Virtual Router first "Turn any Windows 7 or Windows 2008 R2 Computer into a Wifi Hot Spot."
EditByBSEditor: Virtual Router turns any Windows 7 or Windows 2008 R2 Computer into a Wifi Hot SPOT using Windows 7's Wireless Hosted Network (Virtual Wifi) technology.
The Wireless Network Create/shared with Virtual Router uses WPA2 Encryption, and there is not way to turn off that encryption. This is actually a feature of the Wireless Hosted Network API's built into Windows 7 and 2008 R2 to ensure the best security possible.
You can give your "virtual" wireless network any name you want, and also set the password to anything. Just make sure the password is at least 8 characters. http://www.brothersoft.com/virtual-router-327895.html Then install Connectify-Me Connectify is an easy to use software router for Windows 7 computers. After downloading and installing the lightweight application, Connectify utilizes your computers' built in Wi-Fi card to wirelessly share any available Internet connection: a cable modem, a cellular card, or even another Wi-Fi network. Other Wi-Fi enabled devices including laptops, smart phones, music players, and gaming systems can see and join your Connectify hotspot just like any other Wi-Fi access point and are kept safe and secure by password-protected WPA2 Encryption. http://www.connectify.me/ Then reboot computer
1helpful
2answers
Can toshiba p205-s6267 be upgradeed tp windows 7
yes. your laptop can be upgraded to windows 7 but make sure you have with you your original cd installer for your motherboard. also, visit the toshiba's website to see if there are updates and patches for windows 7 compatibility with your hardware.
Set up my printer to work wirelessly with my laptop
Is your printer able to accept a USB ??
Purchase the wireless networking USB connector...Install the software onto your laptop and if your laptop has wireless connections already, it shoudl automatically pick up the printer. If not you need to also purchase a wireless card for your computer.
Top Kodak Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
