Question about Navigon 5100 GPS Navigator Handheld GPS Receiver
GPS signal not sufficient on iPhone 3G
I get "GPS signal not sufficient" every time I try to use it. I kept the application for opened for 10 minutes walking up and down the street and still no signal. Any solutions or explanations?
    New Friend:
Had the same problem with Navigon for the iPhone. I found a simple quick fix:
1. Go to your iPhone Settings
2. Press the General tab
3. Scroll to the bottom and press the Reset tab
4. Press the Reset Network Settings tab
This may take a short time, then after it's done, reboot your device (if it doesn't on its own).
You should now have a good GPS signal!
Posted on Jun 19, 2010
    New Friend:
Brilliant! ensure battery is fully charged. so glad i gave up 2 minutes of my life to follow the link to this forum
Posted on Apr 10, 2010
    Brigadier General:
  • 4,090 Answers
Ensure battery is fully charged
Posted on Jul 06, 2009
6ya staff
SOURCE:
What is difference between iphone and iphone 3g
  • 3G speed capability
  • The iPhone 3G includes a built-in GPS.
  • The 3G is a bit thinner at the edges and includes a headphone jack that is flush to the side.
. The iPhone 3G differs from the iPhone in that it used 3G networking and included built-in GPS for expanded location based mobile services, and new iPhone 2.0 software
, which included support for hundreds of third-party applications that were built with the iPhone SDK
Jan 14, 2013 | Apple iPhone Smartphone
Im my iphone in map i cannot determint my location so please send me manual solution
Do you have wifi or 3g connection? If you are using GPS, it doesn't require a connection, it relies on the satellites. Try running an application that runs on GPS like N Drive for iPhone because the default maps application requires that you be connected through wifi or 3g.
Mar 05, 2011 | GPS
Hi my iphone is not detecting any gps satellite navigation
Make sure you have the iPhone 3G, or newer, because the original iPhone did not have GPS capabilities.
Also, make sure you are in a open outdoor area, (not crowded with skyscrapers)
Go in Settings > General > Location Services and make sure you have it turned ON, as well as all the other apps in the list underneath.
Make sure your phone is not in airplane mode.
Go in the Maps application and press the compass arrow in the bottom left corner. It should locate you on the map with a blue dot.
Feb 15, 2011 | Apple iPhone 3G
When using Navman in my vehicle on the iphone I have the iphone plugged into the vehicle phone charger. After about 50 minutes use runs the iphone battery completely flat and takes about 2 hours to...
that's because your using GPS signal that is constantly resetting itself and it uses battery life to do so, GPS uses more energy than anything else the iphone will do. If your still within hardware warranty call Apple and they might help you with it
Dec 21, 2010 | Apple iPhone 3G
Hi Everyone, I have recently bought a new Iphone
Make sure that your WiFi is not left on all the time and that the signal is strong as weak signal affects the battery. Adjust the screen brightness to low and avoid using the phone for games etc to maximise battery life.
Oct 20, 2010 | Apple iPhone 3G
Navigon iphone 3g no signal
I am using Navigon on the iphone cant get a GPS signal please can you adv
Aug 05, 2009 | Navigon 5100 GPS Navigator Handheld GPS...
How to use gps in iphone 3g apple
simply tap on "maps" on the homescreen to open the Maps application. Then tap on the little circle in the bottom left corner to locate yourself using the gps module.
Out of the box, the iphone 3g doesnt support turn-by-turn directions like your usual tomtom gps system.
You can download apps for that when youre on softwareversion 3.0.
Jul 11, 2009 | Apple iPhone 3G
T Mobile G1 GPS Problems
G1 Gps Problem Fix - I recently had the same issues with the gps giving me the location of cell towers instead of actual location. After looking around the forums, i found the fix and it worked.
Clear you maps cache by going into your application data.
Settings : Applications : Manage Applications : Maps : then push "clear data"
Make sure both your wireless and gps are turned ON
Turn off Phone
Take it outside somewhere that is clear of obstructions (like a large parking lot, or field)
Turn on phone
Once on, press maps
Let it sit in one spot for about 5-10 min, then press my location.
It should find you in just a few seconds. Mine took about 30 seconds.
This should fix most problems you are having.
Oct 26, 2008 | HTC G1
GPS not working
Try this -
1) Settings > Enable 3G Change to Off.
2) Use the iPhone GPS receiver to locate your position
3) Settings > Enable 3G change to On.
There are two positioning systems in the iPhone 3G, one is the 3G network, and the second is the GPS receiver. The problem occurs when the data from the two systems doesn't match.
Jul 14, 2008 | Apple iPhone 3G
Navigon 5100 GPS Navigator Handheld GPS Receiver Logo
4,690 people viewed this question
Top Navigon GPS Experts
Marvin
Marvin
Anthony Ward
Anthony Ward
Are you a Navigon GPS Expert? Answer questions, earn points and help others
