Methods To Solve error 59 of HP-
Reset the printer using the power switch, turn off the printer for a few minutes.
Turn on the printer and wait for the HP colour jet printer to revitalise.
If there's any surge protector remove it.
If the problem continues then replaces the motor.
Greeting,
Rachel Gomez
It helps if you give the model number of the machine.
https://www.printertechs.com/printer-troubleshooting/479-59-f0-error-itb-contact-alienation-error-hp-laserjet-enterprise-color-cp3525-cm3530
SOURCE: Error 59.99 Printer Error
An error occurred in the secondary transfer
engaging mechanism.
1. Faulty secondary transfer engagement
sensor. Replace the secondary transfer
engagement sensor.
2. Faulty secondary transfer engaging
solenoid. Replace the secondary transfer
engaging solenoid.
3. Faulty feed motor. Replace the feed
motor.
4. Faulty DC controller PCB
Action: Replace the DC controller PCB.
SOURCE: hp laser jet 2840 engine error
its the problem of the spinning wheel which pulls the paper that is called engine and that is either getting blocked by any dust particles or got broken internally and has to be cleaned or replaced to make it proper.
thanks.
SOURCE: HP Printer Color LaserJet 2840
I Have A HP Laserjet 2820 on power up went through to scanner bulb warming up then made a clicking noise comming from scanner unit it was trying to escape the case. if this is the same as yours the problem is that the scanner unit can't find the home position strip mounted betweent the gray case wide piece right hand side as you look down on scanner unit with lid up & the top of the scanner glass inside the scanner unit to get to it you must remove top section of the scanner unit & cleean underside of scanner glass please E-mail me if you want full instruction.
SOURCE: hp color laserjet 3550 59.99 printer error
This error shows
An error occurred in the secondary transfer engaging mechanism.
1. Faulty secondary transfer engagement sensor.
Action: Replace the secondary transfer engagement sensor.
2. Faulty secondary transfer engaging solenoid.
Action: Replace the secondary transfer engaging solenoid.
Action: Replace the feed motor.
SOURCE: My hp color laserjet printer
49 errors are usually related to the jet direct network card which may need to be replaced. But if only happens from one user or when printing one particular document or from one particular program then you may have a driver or software conflict.
