I have lost access key
SOURCE: dazzle will only rcord 103 minutes and movies are 120
Are you on Windows? What version (XP, 98, Vista, etc?)
What file system are you using (right click on the drive in My Computer and select Properties)
If you are using FAT32, there is a built in limit to 2GB files. If you are finding that your capture is hitting 2GB (=103min?) and then crashing, this may be your problem. Also, consult the capture settings in the Dazzle software and ensure no file size or running time limitation is selected there.
SOURCE: Pinnale Dazzle DVD recorder doesn't recognize VCR
On the start up of the instant DVD recorder program, you can either use the "let the wizard guide you" or "advance mode"
1. Select source:
you should select the options:
Video standard NTSC (Because this is the default in our region)
Video composite - if you are using RCA (red, yellow and white cables)
S-video - if you are using the cable with several pins in it.
2. Select Burner
You should select the options:
Hard disc folder - if you will be saving the content in your hard drive, the format of this files are DVD such as VOB and IFO etc.
TSST - _ _ _ _ - if you will selecting your DVD drive.
(If you have selected your DVD Burner and you cannot click "next" to proceed to the Third option,
this means that your DVD drive is not able to burn a DVD)
3. Select menus
It must be NO
4. Recording
select total recording time (make sure that dazzle is selected in the "select source" to set the total recording time)
SOURCE: no audio when using "dazzle" dvd recorder
http://www.pinnaclesys.com/PublicSite/us/Products/Consumer+Products/Dazzle/Dazzle+Video+Archiving/Dazzle+DVD+Recorder.htm?view=knowledgebase
Try looking here start there and maybe it will help you out
SOURCE: Dazzle DVD Recorder lags when it records, so video
Disconnect your dazzle and reconnect it at the back of your computer. Click on Start>Control panel>system>hardware>device manager>sound and video games controller> right click on video capture device and uninstall it. Restart your computer. Open your IDVDR and then try to check if the same things again.
