Sometimes you will get it on and it wont turn ofyou haveto turn it of at the wall sometimes if you turn it on and off at the wall you evently get it going sometimes it wont go at all every now and then it will switch on no problem
Sounds like tuner fault. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
SOURCE: Olevia 42"
Olevia LCD 542I - Had the same issue for a week until the tv would not turn on anymore, after several attempts it came back on. A few days later the tv turned off then only the standby light was on, then lost the standby light as well. After researching the problem it could be in two areas, either the power supply or main board. Removed the back and found the power supply had several capacitors that were bulging on the top and appeared the fluid was leaking, all signs of a failed part, removed the PS and replaced four capacitorst that had shown some issues. If you can removed the PS and check for a number on the board, mine was FSP271-4F02, and find someone who has some electronic circuit capablilty, the issue may be resolved at a fraction on the cost of a new power supply.
SOURCE: WHEN ON STANDBY WHEN TRY TO SWITCH ON BLUE LIGHT
Hello, Ur power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get ur tv power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
SOURCE: My Tv wont turn on, the standby light stay orange,
Hi, l had the same problem. HAD !!
l bought a universal remote control (5 euro), but unfortunetly no codes for Acer in it.
Then l did the setting up by auto search and YES : there was a code. But, wheeehh, it did not work.
A little bit sad l took the Acer control and guess what: it worked again!!!!! l guess the TV had a total reset, and l use only the Acer remote control now.....
Female and blond!
