I only have 120 to my heating elements on my water heater GE50t06aag
Test across top two screws on upper thermostat for 240 Volt
Press reset button located on upper thermostat
Reset circuit breaker
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#new
http://waterheatertimer.org/images/Upper-thermostat-w-wire-a-2.jpg
Otherwise elements will test 120 Volt to ground at all times.
http://waterheatertimer.org/See-inside-main-breaker-box.html#main
http://waterheatertimer.org/How-to-reset-circuit-breaker.html
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
SOURCE: How to replace heating element for InSinkErator W154 water heater
take the front cover off, it is just snaped on, there you will see it, depending on the age of the unit insinkerator will replace it for free, you just have to install it, but for the most part it might be cheaper to change the unit
