Ctrfytrtederfrtftrdf
What is your question about using the walkie talkie? These are standard FRS low power walkie talkies. You need to set both to the same channel. Turn both on. Push the transmit button and speak into the microphone which is on the face of the radio. You should hear the voice in the other walkie talkie.
Note; all of these FRS talkies have substantially less range than advertised. They should provide reliable service within about 1/4 mile line of sight, no more. In an urban environment with lots of buildings you will get less.
SOURCE: motorola talkabout ta288 walkie takie
http://www.theusermanualsite.com/manuals/mfg/motorola/motorola_twoway_radio_product_list_4.html
You will find the manual here. The radio is part of the 280 series radios, so there is a general manual on all in that series.
SOURCE: Motorola FV200 Walkie-Talkie
Scanning Channels
Use scanning to monitor channels for transmissions or to find someone
in your group who has accidentally changed channels.
1. Short press MENU until the "Z" appears. The current setting
On/Off will flash.
2. Press either + or – to turn On or Off.
3. Press the PTT to confirm or MENU to continue set up.
Here is a link to the manual http://www.motorola.com/mdirect/manuals/FV200_userguide.pdf
SOURCE: motorola walkie talkie t4508
http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T4500_User_Manual_E.pdf
This one should be a very close match. The T4508 is a foreign version of the T4500.
SOURCE: binatone MR 250 walkie talkie is locked how do i unlock it?
Try holding down the ENTER button
SOURCE: One of my tlkr-t3 walkie talkie's will not recieve.
They worked fine the first time we tried them out. Then they were put away for several weeks, and when they've been switched on, one now doesn't send. I checked this by the other putting in scan mode but it doesn't stop scanning at the channel it is assumed to send with. I tried all the channels for sending but neither one is detected. The other way around, so the first one in scanning mode, the 2nd in send mode, works fine (the scanning stops at the channel of the sending one, as expected).
So my conclusion is, that one doesn't send.
I interchanged the (fresh) batteries, but this doesn;t change.
So what could be the problem?
