Video Cameras Logo
A
Anonymous Posted on Oct 13, 2014
<!-- from fixya rte -->Camera says lens cap on when its not - GR JVC Video Cameras
Errol Hodgson
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 135 Answers
  • Posted on Oct 20, 2014
Errol Hodgson
Expert
Level 2:
New Friend:
Greenhorn:
Answers
135
Questions
0
Helped
82065
Points
140
Lens Cap Error can happen when "eye" of camera goes out "blind". this will require service on the CCD.
How to remove stucked lens cap
It depends what lens cap you have some lens caps you pinch off
Others you pull off some screw off its the easiest thing you can do on the camera you should have had a a1 filter screwed on before the lens cap then all you would have done is unscrew it all.
Then again you may have to take it to Nikon on Wilshire
Lens cap
place the lens cap back and then off the camera. after that turn onn agin and remove safely
Replace lense cover on camera
You can try doing a Google search for your camera make model. I did and found this - below.
btw - Canon is spelled with one "n" which might help in your search results. I'd go to canon usa and click on their link or search their store for your replacement lens cap. Different lenses have different sized lens caps, so be sure you have the right one.
Lens Caps ' Canon Online Store shop.usa.canon.com/shop/en/catalog/.../ef-lens-accessories/lens-caps
Canon Tips & Tricks When using a lens with IS while on a tripod, ... Canon Tips & Tricks That hole in your battery cover has a purpose! ... Lens Cap 14mm f/2.8L II.
2answers
Finepix gives message to turn off then on again. keeps foping it no matter what.
It may be your lens cap. If the lens cap is on, the lens cannot extend, so the camera will give you notice to turn the camera on and then off again (assuming you know that you must remove the lens cap before turning on again. If your lens cap is off, check to see if there is anything else blocking the lens or impeding it from extending.
When turn camera on get message turn camera off then turn camera on again. did that and repeatedly get same message.
Check to see if your lens cap is on. If the cap is on, the lens cannot extend and you will get that message. If your lens cap is off, check to see if there is something impeding the lens and keeping it from extending. Your camera may "think" the lens cap needs to be removed.
After my kids dropped camera on carpet (it was on but lens was not out, they were viewing pictures). The lens will not move, it's stuck and makes grinding noise like it wants to move in and out. After it...
hi dear alexanderesma, your lens have the pin roller's out of cylinder helicoid,some case maybe repaired, otherwise change of lens unit become necessary.
Please send to Nikon service.
Regards
Sony Lens Cap for A100
The Lens cap model of the Camera depends on the model of Lens which you're using with the Camera. The model # of the Lens Cap for the Camera body and the lens differs. Few models and the details are given below:
55mm Front Lens Cap - G Series logo
Model Number: ALC-F55G
72mm Front Lens Cap - Carl Zeiss logo
Model Number: ALC-F72Z
77mm Front Lens Cap - Carl Zeiss logo
Model Number: ALC-F77Z
77mm Front Lens Cap - G Series logo
Model Number: ALC-F77G
α Rear Lens Cap
Model Number: ALC-R55
62mm Front Lens Cap - Carl Zeiss logo
Model Number: ALC-F62Z
49mm Front Lens Cap - Sony α logo
Model Number: ALC-F49A
62mm Front Lens Cap - Sony α logo
Model Number: ALC-F62A
62mm Front Lens Cap - G Series logo
Model Number: ALC-F62G
67mm Front Lens Cap - Sony α logo
Model Number: ALC-F67A
55mm Front Lens Cap - Sony α logo
Model Number: ALC-F55A
72mm Front Lens Cap - Sony α logo
Model Number: ALC-F72A
77mm Front Lens Cap - Sony α logo
Model Number: ALC-F77A
Please enter the SonyStyle webpage and check for the compatible ones for the Lens which you're using.
Thanks for using Fixya.
We wish you a happy holiday season..
Wide angle cap vs wide angle lens
The cap is a plastic disk, usually black or silver, that snaps on at the end of the lens to keep the lens clean. Some lenses have two caps, one for each end when not attached to the camera.
Some cameras don't use a "loose" cap; those cameras generally retract the lens into the camera body and "close" a door in front of the lens.
Many, if not most, camera users do not use a cap (my guess).
The wide angle lens is generally an "optional" lens that can be used for group or scenery pictures when you want to shoot a "wide" picture. A "normal" lens is generally around 50mm (plus / minus 5mm). A wide lens is anywhere from 17mm to 24mm (or so).
I recommend obtaining a wide lens... with a cap.
Hope this helps!
Lens cap
wrong !!!!!! the lens cap is proprietary to the camera I think I might have one if your interested?
2answers
Lost lens cap
I would sugest using an adaptor ring. You can reduce the size of your lens opening down a common size lens cap that will fit your camera. If you can't go this route then give me the make and model number and I will see what I can do for you. LJ
Top JVC Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
