The dvd/vcr has been accidently locked. A dvd was being watched and then stopped and somehow the machine is locked. I am unable to locate the manual to find out how to unlock same. It is an Omni combination player - DVC-6700H. Can you please let me know how to unlock the player.
Thank you
Exactly the same problem. No matter what I do the display flashes up with the word LOCKExactly the same problem. No matter what I do the display flashes up with the word LOCK
The dvd/vcr has been accidently locked. A dvd was being watched and then stopped The DVD was then removed. The door was closed and machine turned off; later that day when we tried to use it the door would not open and somehow the machine is locked. The word lock appears on the screen. I am unable to locate the manual to find out how to unlock it. I have tried Unpluging the systhem while off waiting 10 minutes and pluging everything in again. It is a- JVC XV N50 DVD Player. Can you please let me know how to unlock the player. Thank youThe dvd/vcr has been accidently locked. A dvd was being watched and then stopped The DVD was then removed. The door was closed and machine turned off; later that day when we tried to use it the door would not open and somehow the machine is locked. The word lock appears on the screen. I am unable to locate the manual to find out how to unlock it. I have tried Unpluging the systhem while off waiting 10 minutes and pluging everything in again. It is a- JVC XV N50 DVD Player. Can you please let me know how to unlock the player. Thank you
I'm suffering the same problem and I can't find the remote either which I'm sure won't help :(I'm suffering the same problem and I can't find the remote either which I'm sure won't help :(
vcr will not record it shuts off and when I press play the picture is horizontal lines and makes a loud distorted noise. Tonight I put a Christmas DVD my Sister bought me of three of the worst camp movies and for the first time ever after it finished reading the words " This tape must be Finalized appeared on the screen.Can you enlighten Me ?vcr will not record it shuts off and when I press play the picture is horizontal lines and makes a loud distorted noise. Tonight I put a Christmas DVD my Sister bought me of three of the worst camp movies and for the first time ever after it finished reading the words " This tape must be Finalized appeared on the screen.Can you enlighten Me ?
I have the VR-325 DVD Recorder. I lost the manual and somehow it has been blocked. Now I don't know how to reset the password for the dvd player to work. Please help!! I have the VR-325 DVD Recorder. I lost the manual and somehow it has been blocked. Now I don't know how to reset the password for the dvd player to work. Please help!!
You can't post conmments that contain an email address.
I went to this site and got the users manual
you will need to register first though
if your problem was the same as mine then all you need to do is hold the on button on your remote for 8 seconds
Machine shuts down after 6 seconds...
Answer
Failed: retry
DVD/VCR Combo was working fine then one day machine started
shutting down after a few seconds of...
(More)(More)
shutting down after a few seconds of operation. It happens with both, a
VCR and a DVD. I can watch 6 secs. of a movie at a time.
clean the DVD player with a cleaning kit you buy from any eletronics store. If that does not work you need to service this as the optical laser is not functioning when it heats up at the solder joint this would cause artifacts and freezing as you prescribed. So diagnosis dirty optical laser or malfuctioning optical laser at solderjiont.
I`ve just downloaded these
VCR DVD Combo
Apex Digital
1061
VCR DVD Combo
Go Video
0744 0715
VCR DVD Combo
Hitachi
0000
VCR DVD Combo
Panasonic
1762
VCR DVD Combo
RCA
0060
VCR DVD Combo
Samsung
1075 0820
VCR DVD Combo
Sanyo
0104
VCR DVD Combo
Sony
0864
VCR DVD Combo
Sylvania
0675 0000
VCR DVD Combo
Symphonic
0675 0000
VCR DVD Combo
Toshiba
0503
This is the website http://www.ofausa.com/en/list_codes.php?db_value=expert4&remote_choice=URC 4021
My DVD/VCR Daewoo locked and everytime i pressed a button it just said LOCK! I plugged off the vcr for a few hours and then plugged it back in and pressed the on button. Now im watching the dvd that was stuck inside. Try it, you just never know.
if you have not plug out your set for a while then i recommend to do now leave it for about 2 days then plug it in back if it does the same problem,then have a tech look at your set.good luck
i have same problem with vcr , all mecahnism ok but dvd ok but vcr does not work all mechanism ok beccause i check manul its and are ok let me know if you knw somethins , in your case chech manual it open the dvd internal and check for work manual . wilfred
Thank you
I have the exact same problem-hopefully someone knows how to fix it!!
