I have a proscan 32la25q that the backlight will not come on unless you cycle power a bunch of times. Replaced caps. Its just seem the CCLF's are pulling to much current and causing the driver logic to turn them off. I hot wired the TV to auto cycle power until it come one. These is a Blight OK signal I used to know when the back light are on. Anyone else seen this. The Backlights say on once you get them there. Picture is nice and bright. Really like to fix the solution rather than have my Hot wire keep just cycling power.
SOURCE: hooking up dvd player
You have wires hooked properly.
On your remote, hit input button, press down arrow once to AV then press right arrow button.
Then watch a DVD.
It worked for me.
Good Luck
SOURCE: tv: why do I only get sound when I turn the TV on?
Exactly i do no the problem in the video section.
SOURCE: Proscan 32LA25Q
I have a jvc home intertainment centre and dont pick up the tv with it remote.
what am i doing wrong
SOURCE: Need TV Code
i believe because this is a commercial television. look at the power cord -- three prongs - right?
I had to get a universal remote and program the buttons manually from the original remote to get it to work.
SOURCE: can't get Satalite remote model IRC 451 to work with my tv
theres nothing much i can tell you, i searched google through maybe 5 pages, everyones having the same problems. i'll keep looking for you though
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
