If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
SOURCE: Westinghouse LD-4655VX Power on fine, nice picture, but around 5 minutes turn off self it,
If the set is still under warranty, the power supply board is going bad. If not you can replace it yourself. It's not that big of a job. You can find the parts you need at www.shopjimmy.com
SOURCE: why wont my 47" westinghouse tv ld-4655vx turn on?
Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis.
