Can i charge this camera using a usb cord that goes to a house outlet
SOURCE: Power cord and battery's support NO power to Video Camera
This incident happens often and damages the camcorder's power board. Replacing power board and some adjustment should resolved the problem. Your cost may run from $175-$225 in US for this model. Whenever you are transfering and connecting to pc, it is recommended to connect AC adapter power for this. Do not rely on a charged battery. Good luck.
SOURCE: battery charging problem.
link to the manual
Read page 9 make
sure you have the
right battery and
that everything is
hooke up right
SOURCE: New Batter won't fully charge and camera won't power off
The battery will not hold a charge or cannot be charged at all.
Follow the steps below to troubleshoot this issue.
IMPORTANT: It is recommended that you only use a Sony® brand rechargeable battery.
If the issue is still unresolved, then the
battery may need to be replaced. If still unresolved after trying a
replacement battery, then service may be required. The Sony® eService
Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
SOURCE: JVC GR-D270u Digital Video Camera
Here is the issue. Connecting this camera to your PC via USB will only allow you to download the pictures that you have stored on the camera's SD card. To download video to your PC you will need to use a firewire to 4-pin DV cable. If you do not have the software from JVC, no worries as Movie Maker on Windows XP will import video from devices for you. Movie Maker in Vista will not allow importing video or capturing from devices at all, so you will need to get the JVC software if you are oin Vista.
SOURCE: I have a Flip mino
Try a different USB port and don't use an extension cable with it either. Make sure the computer you are using is turned ON and stays on during the charging. not sure about the second half of your question, not knowing how to open? and change the battery? If you never opened it to begin with how did you get the rechargeable battery pack into it?? they don't come installed. battery was separate in the packaging on mine. anyhow, there is a little slide button at bottom of camcorder slide the opposite direction, then the whole front of the camcorder slides down and off of the camera. The battery pack goes in. the White plastic that covers both batteries Stays on them do not remove, but if there is a little plastic strip covering the connections remove that. I have the Ultra HD and it also takes regular AA batteries, and you may try that too to see if it will work your camera, if not, maybe something is wrong with the camera.
I am hoping you did not think the rechargeable batteries were already in the camcorder and they got thrown away with the packaging !!!! IF so, then use AA batteries instead. good luck. :)
