Switches on automatically when battery replaced.Won,t switch off by power button.
SOURCE: error code 507
Basically this means that there is an error with your BB operating system or software, you will need to reload you app's though apploader through your desktop manager.
Pulling the battery out while the device is on is worth a try before you reload the os, this is called a hard reset and fixes 80% of BB issues.
dear,
i have the problem of 507 error on my blackberry model 7290. please be of help and tell me what to do about it.
thanks
ogbonna
SOURCE: code 507 with circle as soon as i switch it on
Error 507 appears when any subsequent attempts to perform an Application Load or upgrading the software
on the BlackBerry smartphone are unsuccessful
Solution :
1. Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager.
2. Click on the Application Loader icon.
3. Click Update Software.
4. Type your BlackBerry smartphone password (if prompted) and click OK.
5. Select Options under the Device software options section.
6. Select the check boxes next to the names of the applications you want to install.
7. Click Settings, and remove the check mark from the check box for Back up device data automatically during the installation process.
8. Click OK.
9. Click Next > Finish.
10. When the process has completed, the message The loading operation was successful will appear. Click Main Menu to return to BlackBerry Desktop Manager.
If it shows the same error then please visit to the nearest Service centre.
LED Indications
The front panel Status LED provides an indication of
the set's operation and the possible cause of a malfunction.
If an abnormal condition is indicated, perform the
Self Diagnostics procedure.
Self Diagnostics
To activate, press the front panel <ACTIVITY> &<CH
??> buttons at the same time and hold for 5 seconds.
The STATUS LED will then flash denoting a two digit
code.
• The number of flashes indicates the value of the
MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2
second.
• The LED then flashes indicating the value of the
(ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: If the Error Code is "23", the LED
will flash two times, pause, and then flash three
times.
Table 2-2: LED Indications
Error Codes, descriiptions and the most likely cause of
the error are listed in Table 2-3.
Note: The TV must be in "Shut Down." The LED
will probably be indicating an abnormal
condition. If the TV is switched Off, AC is
removed, or a System Reset is performed, the
code automatically resets to "12" No Error.
See the Error Code Log to retrieve a history of
errors.
Note: Use the front panel buttons, not the remote
control.
Note: If there is no response, the front panel may be
locked by a V-Chip setting. To unlock, press
and hold <ACTIVITY> on the front panel for
8 seconds.
LED Indication Condition
Off Off (standby)
Green Power On
Slow Blink Green Power Off with Timer Set
Fast Blink Green (80 seconds) > Off Power Off (Cooling fan still working, 80 sec)
Red Lamp Failure
Yellow TV Too Hot
Slow Blink Red TV May Require Service
Slow Blink Yellow Lamp Door Open or No Lamp Installed
NORMAL INDICATIONS
ABNORMAL INDICATIONS (For details perform Self Diagnostics Procedure.)
