Black & Decker Pivot Plus Cordless Drill/Screwdriver Logo
A
Anonymous Posted on Oct 12, 2014
How to replace batteries on pivot plus ?
Drill is placed on it's charger but does not charge. i suspect it's time to change out the old battery
5 Related Answers
Anonymous
  • 205 Answers
  • Posted on Oct 16, 2009
SOURCE: Have a Fire Storm place battery in charger green
if you have one check the battery and charger with a meter. if there both fine check the prong's on the battery and the power tool. if charger is'nt charging check the fuss in the charger.. good luck let me know.
Anonymous
  • 178 Answers
  • Posted on Nov 25, 2010
SOURCE: I have a B&D Pivot Plus Cordless
If your drill is a model PD600, your battery part number is 5102993-00 and this website is selling it for 15.00
http://www.ereplacementparts.com/battery-p-100105.html
If this helped, please rate me!
Anonymous
  • Posted on Mar 19, 2011
SOURCE: Black & Decker Pivot Plus
this one dosn't charge. It takes batterys. how do i change them
Anonymous
  • 643 Answers
  • Posted on Jun 23, 2011
SOURCE: how do remove the battery
It's in the **** end. You must unscrew all the black screws in the lower handle. Remove the black heel. Then unplug the Red wire. Carefully pull out the battery pack. Then unplug the black wire
You can order a new battery from HERE
agent91
Ned White
  • 2100 Answers
  • Posted on Jun 28, 2011
SOURCE: I have a black &
Batteries are only good for about a year, if they are older than that, take them back to the store and see if they are guaranteed at all, (all Ryobi tools and batteries have a date code on them, and they are all guaranteed for 2 years, a little plug for Ryobi,) that is all I buy now days, they work great. So, to check your charger, you will need a volt meter set on 12 or 20 v dc, and see if the charger is putting out, if not, then, the cost of a new ryobi might be the same as the fix for the black and decker. That is if you use the thing, we use our cordless tools every day and charge them every night, hope this helps.
How do I test a Bosch 12v NiCad battery drill with a multimeter.
If it is 15 years old the batteries will need replacing. They were the worst of all the battery types and were replaced by Nickel Metal Hydride and now Lithium. NiCad batteries suffer with 'Memory Effect' and also lost power in storage. Find the YouTube channel of 'Big Clive', he just did a video on battery types, pros and cons.
https://www.youtube.com/c/Bigclive
IIRC, two terminals are the charging plus and minus and the other two are for the charger diagnostics.
1helpful
2answers
I have a black & decker pivot plus that will not charge. How do I know if I need a battery or if I need a charger?
Battery Wont Charge Up. \r\nTo Replace Battery Cost $17.00 + Shipping WFT I Can Buy I New Driver For $24.00 Why Would I Want To Buy A Battery DUH
It could be a bad battery or charger. I bought a new drill with 2 batteries on sale for $10 more than one new battery. So I would just buy a new one, keep the old one around in case the new driver quits. Or if you use it allot, upgrade to a better brand. It's a disposable world we live in.
My battery charger doesn't charge. Any ideas?
You will to have your charging current/voltage checked in the first place., Use a multimeter and check the voltage of the adapter,. Next remove the drill unit and check the voltage on battery pack with the adapter and without. If there is increment of voltage on the battery then the charger seems to charge and your battery can be the suspect.
Change with the same AH rating.
2helpful
When i place a 18v battery which is dead on the charger both red and green lights come on and stay on. This is happening with both batteries. and neither holds a good charge. What is the problem? It is...
In some model the FUSE got burn.But if this is not your case one or both,batts and charger are burn.Try first to change the batt, then if this not work, change the charger.
2helpful
Will my pivot plus drill work right away if it is connected to the charger?
Hi, no it wont the charger will not give it enough power on its own to allow you to use it, you need to leave it to charge as the charger only trickle charges it slowly to prevent damage being done to the battery, so you cant use it whilst its on charge as this could cause the charger to over heat.
you need to leave it on charge before you use it.
let me know if you need further assistance ok
plz rate this solution as i have a whole page on unrated posts, thanks
I KEEP MY PIVOT ON CHARGE BUT IT DOES NOT WORK
if you know how to use a volt ohm meter you can check your charger, battery and switch.
4helpful
Battery does not charge
Try cleaning the metal connectors that make contact when you charge the battery, also clean the connectors on the charger to. If any of these metal pieces seem to be broke or crooked then try to straighten them,this will make any connection as good as new. If this doesn't help, then a; the battery is not functioning and would need replacement, b there is an internal problem with the drill. Check the charger to make sure it is functioning normal by comparing the charge light to the corresponding meaning. The meaning of the charge light on the charger is usually printed on the top of the charger. If following this doesn't result in you finding a problem with the unit, then it would be time to replace it.
Hope this helped some if so (or not )please rate, thank you!
8helpful
2answers
Power is low. How to charge it?
The pivot has to be in the straight position and the charger plugs in the joint (it's hidden in the bent position)
Top Black & Decker Drills Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Paul Carew
Are you a Black & Decker Drill Expert? Answer questions, earn points and help others
