Before it went out completely the screen would work but was very dim. I thought it may be the bulb but I have replaced it before and the multiple other times I did the screenc o,mpletely went out immediately.
SOURCE: Mitsubishi WD-62327 Screen is very dim
I tooked the front screen off the TV set. I fallowed the instructions from another wrighter. The Bottom mirror was clouded with dust. I used a cleaner made for cleaning ipods and put it back together with instant success. I had not cleaned it since I got it almost four years ago. I just thought it was getting dim.
As far as the VCR playing black and white it also an easy fix. The Satalite Service man was swapping out my receiver and inadvertaly put the device on componite side of the TV. I put them back on Inpute 1 and 2 and they also work just fine. Thank you for your help.
reading other people porblems I was able to repair it on my own.
SOURCE: Buzzing noise from Mitsubishi DLP WD-52327 after replacing bulb
Did your replace lamp come on the screen or did you lose picture? Just because the LED indicator suggest replace lamp it doesn't mean it needs it. If your pix was dull or loss of brightness then replace it, if not then just reset your lamp timer, check your owners manual for instructions.
SOURCE: Getting a loud buzzing noise in the rear of my
I have just experienced the same issue with my mitsubishi WD62525 as well...thought it may have been a lamp issue as well....replaced the lamp with the spare and still have the same symptoms...(only difference is that my timer light just continues to blink green and never turns red???) I cleaned out the rear filter...was not really that dusty so not sure what else it may be????
SOURCE: hdmi 2 wont work on mitsubishi wd-y65
It sounds similiar to a problem we've had with ours, all components would work in hdmi 1, but hdmi 2 would only work intermitently. They ended up replacing the digital board (fortunately we have the extended warrenty, I'm sure it's not cheap). Sorry hope this helps.
SOURCE: I have a mitsubishi wd
Hello
Its bulb has got traoubled or its control circuit has some faut with it. it is not a user serviceable item. Replacing bulb can be done by the user according to the instructions in its user manual. But trouble shooting its control section must be done be any experienced service technician. OK.
