Do you mean the KX-TGF370 series phones? Panasonic doesn't have a KT-TGF370 to my knowledge.
To remove a single number from the Call Block list, press Call Block on the handset (below 0) or Menu # 2 1 7 at the base. This gets you to the Call Block sub-menu. Choose the line for Block a single number with the up/down arrows and press Select. Navigate with the up/down arrows through the list to the specific number that you want to remove from the list. Press the soft-key for Erase. Use the up/down arrows to highlight Yes and then press Save. If done, press Off or Exit.
To remove a group of numbers, again press Call Block or Menu # 2 1 7 depending on whether you use the handset or the base. Highlight the line for Block a range of numbers and press Select. On the handset, press Menu and highlight Erase All. Press Select and then highlight Yes and press Select. Highlight Yes and press Select again. Press Off to end.
On the base, you press the soft key for Erase. Highlight Yes and press Select. Highlight Yes and press Select a second time to confirm clearing the memory of all blocked numbers. Then press Exit.
See page 34 of the manual for these details. The manual is available from Panasonic here:
ftp://ftp.panasonic.com/telephone/om/kx-tgf372_en_om_.pdf .
I hope this helps.
