The serial number of the Johnson outboard is J0262671, I need to know what model this motor is
SOURCE: 1974 60hp johnson outboard won't run on full throttle.
Carbs probably need to be cleaned and re-built. Common problem in outboards that havent been run in a while
SOURCE: Looking for a starter solenoid wiring diagram
save yourself some money and go get a lawn mower solenoid and find a way to mount it yourself. I have done a johnson outboard and a tigershark jet ski this way with no problems.
SOURCE: do i need to mix fuel for a 1988 15hp johnson
Yes.Fuel mix is needed.Mixture is 50/1 fuel /oil. Eg.50 litres of fuel/1 litre of oil.Oil bottles you buy have measurements on the side of them.Hope this helps
SOURCE: I can't find a vin number on a johnson outboard
model and serial numbers are located on small plate rivited to the transom mnt on the outside tiller side verticle surface. if not there, consider if perhaps has been removed. if you find evidence of this, mtr probably hot, or stolen.
Testimonial: "I was able to lift the cover off the motor and locate it. Thanks for the respnse!"
SOURCE: need exploded view of 14 hp johnson outboard motor fuel pump
Need year mode?. But you can go to this website and get all you need. Don't worry I'm not a salesman. I just use this site for my own business. www.crowleymarine.com. click on parts catalog then follow directions.
