Question about Kodak EasyShare Cameras
My camera is showing error L02 every time I turn it on and the lens does not go back in. how can I fix it?
6ya staff
SOURCE:
Misty Hoffman
  • 374 Answers
SOURCE: camera shuts off lens error
"lens error" will only be fixed by sending into repairs. 800-706-2534 and keep choosing option 2. Tell them you have a lens error and they will tell you where to send it.
Posted on Mar 30, 2008
Anonymous
SOURCE: Canon Power Shot SD600 - Lens Error
http://photography-on-the.net/forum/showthread.php?p=5844033
Posted on Jul 11, 2008
tatiya123
mukesh tatiya
  • 14 Answers
SOURCE: lens error
I have a solution posted in doc "nikon s5 s6 lens cover error repair.doc"  uploaded on site http://www.esnips.com/web/papputatiyasStuff    It will be helpfull for you. Its is a step by step solution with images.
Regards Mukesh
Posted on Mar 25, 2009
Anonymous
SOURCE: Canon SC100 Lens Error
I have a 3 year old Canon PowerShot SX100 IS. While testing an external battery power supply I built, the external power connector pulled out while the lens barrel was extending just after I turned on the camera. Power to the camera was lost before the lens barrel fully extended and wouldn't reset when I repowered the camera. The dreaded error message "Lens error, restart camera" appeared and the camera shut down. I restarted the camera over and over and over again but the lens wouldn't reset. I was extremely lucky to find the information here and read various fixes. I didn't want to take the camera apart so I tried various fixes others have successfully used. I first tried smacking the bottom of the camera hard with the palm of my hand just after pushing the on/off button but that didn't work. The one which worked was smacking the camera on the side immediately after I pushed the on/off button. I smacked it quite hard twice with the palm of my hand then, suddenly, the lens barrel began to move and the lens reset itself back to its starting position. Thanks to everyone who has posted here!
Posted on Apr 11, 2009
ginko
Ginko
  • 19396 Answers
SOURCE: Lens error, restart camera
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Posted on Jul 05, 2009
Lens error, restart camera camera shuts off
Try one of these two fixes, if they dont work for you follow the link below for further troubleshooting.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 (for older Canon's) means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time
Aug 13, 2010 | Canon Cameras
My camera is saying lens error and it wont open the lens
Aug 12, 2010 | Nikon COOLPIX S230 Digital Camera
My digital camera has a lens error
Jul 24, 2010 | Nikon COOLPIX S570 Digital Camera
Lens error, lens do not open
Jul 14, 2010 | Canon PowerShot A1100 IS Digital Camera
When i turn on, it says lens error, restart camera - i"ve turned the camera on and off several times and nothing happens, the error message continues to show. I've taken the battery out and put back in but...
Jul 05, 2010 | Canon PowerShot SD770 IS / IXUS 85 Digital...
Lens error; restart camera
Jun 15, 2010 | Canon PowerShot SD600 Digital Camera
Lens error :0x01110000 That's what it says when
Jun 12, 2010 | Pentax Optio 60 Digital Camera
Problem with my kodakz712 error l02
this is a hardware error of the lens. You can't repair it by yourself. You have to send in the camera in for the repair. Contact kodak under 1-800-235-6325 or follow the step-by-step solution tool under www.kodak.com/go/itg.
Feb 12, 2010 | Kodak EasyShare Z712 Digital Camera
Lens Errors 17 & 27 on Sanyo VPC-E760
My camera was showing lens error 12&25 and then shutting off. I tried gently trying to twist and pull the furthest out part of the lens and it popped back into place easily. It made a noise when it did this, and then i turned the camera off, and the lens went back in!! Completely fixed now!!
Aug 03, 2008 | Sanyo VPC-E760 Digital Camera
Lens error 25 and 15
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Mar 25, 2008 | Kodak EasyShare C330 Digital Camera
Cameras Logo
91 people viewed this question
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
