My sewing machine will only sew backwards
SOURCE: singer fantasia II problem
Check the reverse lever.
Most probably it's stucked in, the last time you used it.
SOURCE: backward stitching
Knowing which kind of machine you have helps alot. Just guessing but maybe the reverse mechanism is stuck and needs some oil in it to free it up. Or the buttonhole mechanism is stuck in reverse part of it.
Probably you should have it looked at.
SOURCE: Singer sewing machine beeps and wont repond to commands.
Sounds like you may have a blockage somewhere in the bobbin area that needs cleaning as this is normally what happens when it gets jammed. Reverse sewing can sometimes cause jams. Remove bobbin area and reassemble.
SOURCE: My sewing machines reverse sewing botton seems to be broken
You should call Singer Consumer Affairs at 800-474-6437 or email them at [email protected].
