LG WM2487H Front Load Washer Logo
Posted on Jul 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
After a wash cycle, the letters UE appeared in the timer window..
After a wash cycle, the letters UE appeared in the time window...and the rugs were sopping wet...what does that mean?
Anonymous
Level 3:
  • Master 1,543 Answers
  • Posted on Jul 05, 2009
Anonymous
Master
Level 3:
Answers
1543
Questions
Helped
751152
Points
5690
UE = Unbalance error.
try to use a low spin speed with loads like rugs, and try to get as even a load as possible. (ie: not just one rug) Don't wash rubber backed rugs, as the backing can break up and clog your machine.
Now, if you are successful washing with the lowest spin speed, you can hold the " Spin Speed " button in while pressing on the power button. Release power button. Now release the spin speed button. Now, press the spin speed button until the next higher spin speed from your last successful spin. Press start. Your washer should now pump out and attempt to reach the new spin speed, without adding any water. (usually about a 14 minute pump and spin cycle) Don't expect to be able to spin out rugs at a high spin speed.
UE error on LG Tromm it drains but won't spin. I checked the filter and the filter is not blocked
UE= uneven ?
Remove any every heavy items such as floor towels or rugs. Is the machine draining completely or leaving lots of water behind? If not draining check the drain divirertor valve.
UE Error Code on LG Tromm Washer
From back or underneath, check that all three shock absorbers are attached. Take top off and check if both springs are in place and un broken
Maytag centennial washer not working properly in Normal cycle. After it shuts off there is still water in the bottom of the tub. I can move the dial to another setting such as Casual cycle or Heavy Duty...
We have the same problem. The Normal cycle still works, but after the final spin cycle, water is again added (1 gal est.) and the machine stops. Problem occurred after washing an old 25 x 30 inch rug which partially disentegrated when washed. We were seeing particles of the rug in subsequent wash cycles during drain into laundry tub. Don't know if something is plugged in the washer or if it is something else. In another load after the rug wash, the top of the washer was lifted during the wash cycle. The water problem occurred immediately after lifting the lid as the wash load went through remaining cycles. Maybe this affected the timer? Maytag customer service suggested unplugging power cord to re-set timer. This didn't make any difference. We need a technician to tell us if this is a timer problem or something else?
Sometimes on the wash cycle the machine stops and the lettering ue appears on screen and flashes
Two possible problems too much weight (pieces of clothing) and second you need to redistribute the load to make it even, and re-engage the wash cycle again. Good Luck
16helpful
2answers
What does UE mean in the window of my washer
UE = Unbalance Error. If you are doing a large item and cannot add, reduce, or adjust the load, try adjusting the spin speed to a low spin speed setting. If the load is still too wet, you can run just a pump and spin by turning on power and then selecting the spin speed, one setting higher than the last one which ran the full cycle through without resulting in the UE code,(without selecting a cycle) and push start.
4helpful
Error code UE on LG F1247 TD5 washing machine
it means uneven load do u have a pillow in there or something that soaks up lots of water!!
21helpful
3answers
My samsung 7kg front loader keeps flashing UE on the error code (spin cycle) and I can't open the door
Laundry load is unbalanced, manually loosen any tangled laundry.
If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
2helpful
Letters UE on display
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
