Question about Proscan 10.1-Inch Internet Tablet, Capacitive Touch Screen, Android 4.0 with Front Camera, 1.2 GHz, 1 GB RAM"
Why won't my new Proscan tablet charge properly?
The tablet came new with a 16percent charge and after hours of charge time will not charge beyond 19percent.
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 64 Answers
The battery can't hold the charge. Defective.
Or the charger is defective and not outputting enough voltage.
This can be tested with a voltage tester. The charger should be outputting 5 volts.
A good purchase is an inexpensive voltage tester. Can be used for so many things.
Posted on Oct 11, 2014
6ya staff
SOURCE:
How long to charge kindle fire hdx when new
It should take under 6 hours for a full charge.
Feb 19, 2015 | Amazon Kindle Fire HD
I have trouble charging a Acer icona one 7 tablet, any ideas?
first of all these tablets take a long time to charge. second check the cable were you plug into tablet to make sure the holding clips are working and take hold. My first choice and most inexpensive is to buy a new charger. Also check plug in port for damage. look at warranty to see if it is still covered and get replaced. />
Feb 06, 2015 | Tablets & eReaders
What do i do if my Samsung Galaxy tab 2 isnt charging at all?
try a different USB / Charging cable. If still not resolved, replace the battery.
Oct 19, 2014 | Samsung Galaxy Tablet PC
Won't charge
Please make sure the tablet is charged for at least 4-6 hours. Also, make sure the correct button is being used, oftentimes we hear the back or home button has been used in error. If the issue persists, you can try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
If your tablet does not have the reset button: With the tablet plugged into the charger, hold the power button for 10 seconds then click the volume up once. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
Support Troubleshooting Guide
Feb 25, 2014 | Kocaso M M9100 9-Inch 8 GB Tablet
Battery charing very slow, can't open tablet - won't turn on when button is pushed
The battery on the Asus does take a very long time to charge (over 12 hours before you use it the first time, then 8 hours or more each time). It takes even longer if you charge it from the USB port in a computer rather than connect it to its dedicated charger, or if you use it while it's charging. If you've already charged it for 8-12 hours, try turning it on by pressing the power button *and holding it down* for a couple of seconds before releasing it. Then, when using the tablet, try keeping it hooked up to the charger when possible, or at least recharge it overnight.
You can check on battery charge by tapping "Settings" at the bottom of the Home screen, then tap "Battery" in the Device category. The % charge will be at the top of the screen. I enjoy my Asus tablet, and it's good for several hours at a time between charges, but you do have to keep it charged up. Good luck!
Dec 18, 2013 | ASUS Transformer Book T100
Asus transformer T100T battery takes hours to charge & tablet won't turn on
So, greyhen2, we meet again. Here's the answer I gave to your other posting of this same question:
Dec 18, 2013 | ASUS Eee Pad Transformer TF101A1 Tablet...
IRulu Tablet won't turn on anymore
Are you certain that you have progress with full charging?: Sounds like battery issues.
Is the tab an older model? Lithium Ion batteries reach the point at which they are totally spent, finished, and worse than worthless. Until then, and continuously, they spew power--no matter what. That's why that chemistry is used for PC and laptop CMOS batteries---that keeps your settings and the clock going when AC or the main battery goes down or merely is turned off/disconnected. Alternately, internally the connection inside your tablet may have jarred loose, instead.
Replacing or fooling with the battery or connectors inside likely is beyond the scope here. (Remember, this kind of battery (similar to those used in smartphones and cell phones) may explode--even catching fire or otherwise--spewing acids may harm unprotected eyes, skin etc. Have yourself and anyone nearby and involved wear eye protection.)
Best bet--leave the tablet as is: If you are under warranty, get an RMA from the vendor (or the warranty company--or the tablet company) and return (obtain a replacement or refund).
Otherwise, purchase a new tablet--if the tablet is older (than Android 4.0 (Icecream)) that's a great idea. (Even Icecream is getting old now, too.) Otherwise, have someone help you to replace the battery. Obtain repair help from a pro at a shop--or, have a willing and knowledgeable kid or tech friend assist. If fortunate, they may be able to remove the battery (if possible). They may then also help search online, and thus help you to obtain and replace it with one with new--OEM (original equipment) or compatible. Alternately, they may repair a faulty connection for you.
Dec 16, 2013 | Irulu Tablets & eReaders
My Samsung Galaxy Note 10.1 battery not charging can you please tell me why
Same problem on my Samsung Galaxy Note 10.1 (GT-N8013) w/ OS 4.1.2
It just boots up and shuts down.
Dec 06, 2012 | Samsung Metallic Gray Galaxy Note 10.1in...
Charged sylvania tablet for 24 hours & unplugged it but no power
Many times the cause of this problem is u need a new piece where the charger plugs into the device because it shorts out.
Aug 20, 2012 | Sylvania Sytabex7-2 7" Tablet Express Plus...
Proscan 10.1-Inch Internet Tablet, Capacitive Touch Screen, Android 4.0 with Front Camera, 1.2 GHz, 1 GB RAM" Logo
263 people viewed this question
Top Proscan Tablets & eReaders Experts
 Mike M
Mike M
Pollo
Level 1 Expert
Harrie
Are you a Proscan Tablet and eReader Expert? Answer questions, earn points and help others
