Denon AVR-1082 Receiver Logo
Posted on Jul 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can not get the receiver to recognize more than one digital audio input. I am trying to use digital audio from my direct tv receiver, and my ps3 player. I have tried about a thousand things. the best I have done is have it recognoze digital audio 1 (not 2 or 3). the manual doesn't even talk about digital audio.
Anonymous
Level 2:
  • Expert 119 Answers
  • Posted on Aug 02, 2009
Anonymous
Expert
Level 2:
Answers
119
Questions
0
Helped
61291
Points
167
With all your digital connections made once you select that source press the input mode button on the front to select auto this should give you digital sound
When i hook my ps3 to the receiver i only get audio??
Make sure that you have a connection from video out to the TV, from the input you are using for the PS3 on the receiver. The connection for video to the TV is labeled "monitor out" on the receiver. You can use one of the following for it; composite, component or S-video. Or...
Your best results however for your hardware, is to connect your PS3 directly to the TV, then connect the "audio out" from the TV to the receiver. Then select on the receiver the matching input you connected the audio to from the TV.
1helpful
Hi i can't get any sound thru my speakers. I have hdmi from ps3 to tv optical from ps3 to receiver. i have tried dvd video 1 video 2 what setting am i missing? thanks
first: make sure you have the audio output setting on the ps3 set to digital optical output
second: make sure you select whatever the optical input is assigned as, probably dvd. i think there is a button on the front of the receiver that says digital input, make sure you hit that. A little light on the front screen of the receiver will say digital.
Greetings- my denon avr2802 is connected to ps3 for blu ray movies, games and music. The ps3 image goes directly to tv with hdmi and sound from ps3 goes to the denon using digital audio cable. Sound for...
Set the receiver for auto audio input - I think that you are getting caught out between MPEG and DTS audio. If you have the wrong one for the audio source then you hear nothing.
1helpful
No analog comming out of receiver when optical input is used .
as a rule...in order to get analog audio out of a receiver, it must have an analog input. you could use a digital to analog converter between the tv and stereo or come out of both of your source devices (ps3, cable) with analog to the receiver. good luck
3helpful
I have my PS3 plugged into my RX-V365 via HDMI then i have my RX-V365 plugged into my Sony Bravia, the problem is i get no Audio through the HDMI input on my Amp but it still comes through the TV how can i...
Run optical or digital coaxial from your PS3 to the receiver and HDMI from the PS3 directly to the TV. Your receiver's version of HDMI will not work, it's 1.1 and cannot be updated. That's the fix, if you want more info on HDMI problems google HDMI issues or problems and you will find thousands of posts and forums on this issue. Short answer though is, you either need a receiver with version 1.3b HDMI or run optical or digital coaxial for audio to your receiver. Hope this helps
1helpful
PS3 surround sound
You will need the optical cable. My receiver only passes video through the hdmi. So I hooked up the HDMI cable to the tv, and the optical cable to the receiver. Once that is done you have to go to the audio settings for the PS3 and chose audio through the optical.
Denon AVR 2800 digital hookup to PS3
If your TV has an HDMI input, hook up the PS3 w/an HDMI cable to the TV. This will give you a high def picture (set up the PS3 to output the max resolution your TV displays). That will take care of the video side.
Next hook up an optical cable from the PS3 to the receiver. In the PS3 menu, you have to change the audio settings to output the sound via the optical cable.
Finally to get sound out of the receiver to the speakers, you have to setup the receiver source input. For example if you setup the PS3 to play thru "VCR" input, then you have to make sure the VCR input is setup to use either optical 1 or optical 2 for sound (whichever one you have the optical cable plugged in from the PS3).
  • I found this solution on a different site... it worked for me. I needed to change the sound settings in my ps3 to optical... then i selected dolby 5.1.... that took care of my sound.
3answers
Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Is Yamaha HTR-640 a receiver? Try HDMI from PS3 to receiver or Sony HDTV. If HDMI from PS3 to receiver the you need and HDMI from receiver to out Sony HDTV. You could connect everything to receiver and HDMI out to HDTV. You can not have an HDMI cable AND an optical cable coming out of the PS3, only one or the other.
HDMI AUDIO NOT PASSING THROUGH?
OK try to connect all to tv and from tv connect the sound in digital to H/K receiver and you will have sound at the receiver no matter what.
1helpful
2answers
Hooking up a sony playstation 3 with digital optical cable
Here's one solution, if you have an audio output from your tv, you can go from the audio output on your tv to the audio input on your receiver that way anything that is playing on your tv for example, playstation 3, dvd player etc. Anything playing on your tv will have audio on your onkyo home theater system. The other thing I would try if you want to hook ps3 directly to receiver is go to your connection settings on your ps3 menu and change your connection method to digital optical cable.
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
