I take it that you have a 2-stage snow blower, that is is has the auger blades and then the 2-stage impeller. The impeller blade is damaged <<OR>> the motor is to small to through the snow far. If you have a 5-horse engine and throwing heavy snow, the snow may not go as far as the light fluffy stuff.
A single stage snow thrower is not designed to throw snow far, just move it over a bit.
SOURCE: screeching snow blower
On one side of your machine you will find a cover that you can remove, the belt for the auger is in there. From what I can see there is no adjustment. Check to see how the belt looks.If it's chewed up it will need to be replaced.If you remove the belt try to turn the impeler to see if it turns freely, if it doesn't then check to see if there is something wedged. if nothing is wedged and the belt is off and it still don't turn by hand it could posibly be a bad bearing.if it does turn by hand. Also check the belt pulleies to see if they are ok, the only pulley that will sshould spin freely is the idler pulley, the one on the engine shaft should spin the moter so make sure you pull the spark plug wire off to check that one, and the auger pulley should spin with the auger.
SOURCE: My toro 1128 OE snow blower wont throw snow the
I have a toro 98 cc powerlite snowblower model 38182 it was running fine one day then bog down and died after that i cant get it to start it has a good fire on the plug plug isnt very wet it pops threw carb once in a while help
