Question about Brother Hl3070cw Hl-3070cw Color Laser Printer
How do I clear the Print Unable 28 message from my Brother HL-3070CW Laser printer. It says to just turn off then back on again but message alert still remains.
6ya staff
SOURCE:
Anonymous
SOURCE: Paper jam with Brother HL-2030 laser printer
Being a retired electronics technician, I located and downloaded a copy of the service manual. Then proceeded to hunt for the reason why the Paper LED was staying on. I put the printer into the Production diagnoses mode, then by process of alimination opened and closed each panel and cheack each sensor switch one at a time. At which time it was apparent the problem was the rear door sensor. So I started to disassemble the printer getting instructions from the Service manaul, as most electronic equipement there is a sequence process to accompliah this. and once I found that the method of the rear door sensor operated I found the bracket was not in the right position. I put the sensor bar back into it's proper position and put the printer back to normal opperateing mode, I found my problem was solved. So I reassembled the unit and plugged it back into the compter ran a couple of test sheets and cleaned and aligned the printer head(s) made a few adjustment and everything was back to normal.
I must say that locating the Service Manual was a feat, but worth every cent I paid for it which was $9 USD. Personally i think all service manuals should be available for all Brother products for a fee, then a large number of problems can be fixed by the owners without much bother to Brother.
I ahve two of these printers and would still purchase a Brother colour printers, my next purchase is going to be a Brother color laser printer. Out of all the printers i've used on my computers I like the brother the best.
Posted on Mar 22, 2008
Anonymous
  • 66 Answers
SOURCE: My Brother HL-20 laser printer
All laser printers have 2 cylinders in the image..the mag roller, and the drum.
Usually the drum is marked by a foreign object  e.g label or someone has touched it with their finger.
If you replace the cartridge your problem should go away
Posted on Dec 14, 2008
Ekse
  • 13434 Answers
SOURCE: where can I get brother hl-2030 LASER PRINTER DRIVER
Hey,
The brother drivers and software require for the machine is available at
http://www.brother.com/E-ftp/info/index.html
Let me know if you need anything else.
Thanks,
Ekse
Posted on Mar 05, 2009
Anonymous
SOURCE: can i print envelopes addresses on brother HL 2140 laser printers
The manual by-pass slot just below the brother name on the front allows a user to load envelopes just put the envelope in the slot and adjust the size.by closing the two grey tabs
Posted on May 01, 2009
n25an
Norman Davis
  • 622 Answers
SOURCE: black lines down side of paper on HL-5370 brother laser printer
you have a bad drum... it needs to be replaced
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Posted on Dec 27, 2009
Brother HL-3070CW burning smell
Did you run labels or paper the is not compatible with laser printers?
A label may be stuck on the fuser. There's not much you can do unless you know how to remove the fuser.
Oct 08, 2013 | Brother Hl-3070cw Digital Color Printer...
Print unable 28
Error code 28
Print Unable 28
Turn the power off and then back on again.
Drum drive motor 1 (K, Y) failure
Sep 07, 2013 | Brother MFC-9840CDW Laser Printer
Printer HL-3070CW - LOUD Grinding noise when it seems to be running large print offs. It is almost like it gets too hot
My 3070CW makes the same noise. It is caused by the transfer belt. One roller is driven by a cog and this goes fine. The other roller has a tensioner and this roller is making all the noise. While the noise is really loud and annoying - it is completely harmless. Hope this helps.
Aug 09, 2011 | Brother HL 5250DN Laser Printer
I have a Brother HL-3040cn printer, led display says "unable to print 1A" how do i clear this? It also says to turn the power off and open the top cover wait 30 minutes then turn it back on. But...
I have a Brother HL-3040cn printer, led display says "unable to print 1A" how do i clear this? It also says to turn the power off and open the top cover wait 30 minutes then turn it back on. But this doesnt work?
Apr 20, 2011 | Brother HL3040CN Laser Printer
Our brother printer wireless hl 3070cw will not print, it is telling us that it is ready but will not print
it would have print archive in its job print .. check and delete . or install printer again .
i hope it shall work .,
Mar 29, 2011 | Brother HL3070CW Compact Digital Color...
Brother HL 3070CW says the toner is low and won't print. It has toner and I have to get something printed for a client
I done on my brother lh3070cw printer cartridge on Message "Low Toner"
First I take off toner cartridge
second - Covered the both Glass Buttons of Cartridge situated right and left side of cartridge (all cartrideg) for Black Electric Tape.
thent install the cartridge in the printer again.
after install the cartridge press SECURE PRINT AND CANCEL BUTTON SAME TIME AND CLEAR THE STR AND STD FOR PRESSING ok BUTTON FOR 2 TIME.
ERASE EACH STR AND STD
THEN PRESS CANCEL
YOU CAN USE YOUR PRINTER FOR END OF THE TONER
Mar 28, 2011 | Brother MFC-9440CN Laser Printer
Print Unable 20
Bad news. The laser diode responsible for printing black has up and died. You need a new Laser Unit, part number LR1461001. Brother has released a "Service Update" about this one; the instructions for replacing the laser unit run to nine pages. If you're within the 1-year warranty, it won't cost you, but it won't be printing with it today.
Jun 11, 2009 | Brother HL-4040CN Laser Printer
Message E52 Service call what does that mean? (Brother HL 7050)
Probably a fatal error. Bad Laser Unit. Try unplugging the power cord for 10 seconds.
Jan 06, 2009 | Brother HL 7050 Laser Printer
Brother HL-4040 Laser Printer -- Print Unable 6A Error
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 05, 2009 | Brother HL4040CN Laser Printer
Brother Hl3070cw Hl-3070cw Color Laser Printer Logo
304 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Jim Keysor
