6 cd player wont play when the car has been runnin
SOURCE: 2003 BMW CI Convertable Radio/CD Problem
Had the same problem with my '03 330xi. Navigation worked fine but radio and CD did not work at all. I opened the fuse box located in the glove compartment to check the three fuses associated with the navigation system and radio. #7, #39, and #41. All three fuses were intact so I put them back in. I then put the key into the ignition, turned it to position 2 and miraculously the radio came to life. I guess it acted as some type of reset?
SOURCE: My Bmw 325 SE cd player wont work...but the radio is working
The carriage inside the cd player is half way in mode. Which means the cd has to be removed mechanically. In order to do this a qualified technition needs to dismantle it. On some models there is a reset switch next to the eject button on he changer. It will be very small. like the size of a paper clip hole. push in with a pin. Otherwise go to stereo shop
SOURCE: FM Radio quit working
The only way to get the car out of transport mode is for the dealer to plug the car in to the main diagnostic terminal and download the software to activate all of the control modules. This has to be done to all new cars arriving from the factory.
As your car is a 1994 this reason is highly unlikely for the radio to off stopped working.
It sounds to me that the actual radio tuner has given up, in short you may need a new radio.
SOURCE: I have recently added a Bluetooth ULF module to my
Hello Richard, when the ulf module was installed, was the jumper plug installed in the blue 26 pin connector in the left rear corner near the GPS unit. I think that if this plug is missing, you will not get any sound for the interface. This plug is required for vehicles with nav. I think it is called the Voice Input jumper plug.
