Dehumidifiers Logo
A
Anonymous Posted on Oct 10, 2014
Why is my ebacnot working blue light comes on then goes of and red light comes on why
J.D. Browning
Level 3:
  • Master 2,760 Answers
  • Posted on Oct 23, 2014
J.D. Browning
Master
Level 3:
Answers
2760
Questions
0
Helped
1015030
Points
6696
The units self testing and it takes a moment to ck that everything is ok , red light ind. it;s found a problem , ck simple things first , empty bucket, ck float sensor inside bucket ck for Level (gravity) ck filter for cleaning and reset filter alarm if present , then move on to more difficult things like is something wrong with cooling fan or did water get inside and dammage something
Red light wont go off
Should have bought a Vicks! My red light goes OFF! No it easy. Unplug the unit for 10 minutes. Fill up with water while waiting. Turn it on! If the red light still come on then you gots scale or build up inside that needs to cleaned out. Follow or call manufacture on how to clean unit...
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
I have a delonghi des 14 dehumidifier. Usually it goes into pause mode for 3 mins when you first turn it on with the yellow light on and then starts dehumidifieing.It now stays in the pause mode forever...
Just fixed this problem with my DES14. Its a fault with the circuit board inside the machine and is very easy to fix, even for a novice. Here is how to do it:
1) Open up the machine by removing the screws in the case. (Make sure it is unplugged!)
2) Locate the circuit board on the side of the unit.
3) At this point you have two options. If you want a unit with full functionality you need to buy a replacement circuit board. I found one on MasterSpares (http://www.mastersparesonline.com/product/index/10147) It costs about 30 pounds. Simply remove the old board and replace it.
4) If you want a working unit for no extra cost (but without the functionality of the humidistat) then remove the rectangular white connector from the circuit board which has red,blue,white and yellow wires entering it. Add an extra wire between the central white wire and the red wire that is adjacent to the yellow. (see photo).
5) Re-assemble the unit. If you have opted for the free option the unit will work when you plug it in and switch it on but will no longer cut in and out with different humidities (or have the annoying warm up period). Thankfully the water overflow cut-out will still work.
Hope it works for you! Feel free to ask if you are confused!
AMB 10000E Red light on the right of the control screen is on. What does this mean?
i have this problem too...red light, no explaination. did you find a solution?
I have a Silhouette dehumidifier model # DDR583R which is about 2-3 yr old. The red light indicating a full tank is on and no water is collected. When I checked the sensor & manually pushed it the...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that explains what can be happening to make the dehumidifier show that the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
3helpful
I have a old Kenmore 40 dehumidifier and the pan light is on. So, I checked the pan and there is only small amount of water. I dumped it and put the pan back and the light is still on. The light goes off...
That is normal. Check the little lever inside the bucket to see if it is moving freely.
There is a little red button that you can see inside the left front side (looking at the unit) when you remove the bucket. Press the button to see if it is sticking.
My lg 30 is not working.
It is supposed to. There is a float that rises as the container fills. When the container is filled to capacity, the float is at its highest point and the humidfier turns off. At the same time, the red light comes on. This is normal. When you remove the container, the red light stays on b/c the float is still at its highest position. It is designed to do this so the humidifier doesn't run when the container is not installed. If the light does not turn off after you replace the container, give the humidifier a tap to move the float back.
5helpful
Red light comes on for no reason. Danby DDR6588EE dehumidifier
I have a DDR4588EE (same model with 45 pint capacity) and had the exact same problem. It's caused by the float at the top of the bucket being in poor contact with the "full" detector button. When the bucket is not full, the float on the bucket is supposed to press against the button. When the bucket fills, the float is supposed to push up off the button which causes the unit to stop and the red light comes on. The problem is that for some reason, the float isn't pressing hard enough against the button to push it properly in when the bucket isn't full. I fixed it by sticking a few little squares of duct tape (3 or 4 layers) on the float to make it press the button more firmly. Seems to be working fine now. Careful not to put too much tape or it might press too firmly which would result in the float not releasing the button when the bucket is full, and water will spill over.
Top Dehumidifiers Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Dehumidifier Expert? Answer questions, earn points and help others
