From 1-5 which is closest setting
SOURCE: purchased a 2004 upright freezer i dont know how to set temp
sir seven is the coldest setting. Good Luck
SOURCE: i have an older whirlpool freezer i just need to
usually the higher the number the colder it gets. Easiest way to tell on all models is the number closest to off is the warmest setting... Eric
SOURCE: how do I adjust the freezer temperature on a
Sorry there is no manual on-line for the freezer. But I can tell you this 7 is the coldest and 1 is the warmest.
Good Luck and Please rate 4 thumbs up for the free answer.
SOURCE: I need to set the
On a freezer or fridge usually the highest number is the coldest setting but this may depend on the model of the freezer.
Testimonial: "The response to assiting in solving the probelm was quick and right on target. Thanks for the efficent service"
SOURCE: I have a kenmore upright
I keep min two notches from the coldest setting.A great way to check where you should set yous,is ice cream.Put an open container of ice cream in the freezer,and turn the freezer to coldest.The next day try to scoop the ice cream.If the ice cream is hard the freezer is too cold.Adjust the freezer two notches ,and try the ice cream the next day.Repeat till you are happy with the hardness of the ice cream.It should be easy to scoop but not too soft.
