Will the heat from cast iron ruin the stove top on a Frigidaire Gallery Stove Top and Oven model?
Hello friend, thanks for your post!
It is not recommended to use any cast iron pots or skillets on a Frigidaire smooth top. In your manual it provides the best type of cookware material and cast iron is a poor heat conductor. Due to the weight of the cast iron it can cause scratches or damage the cooktop. I hope this information has been helpful. -Matt
SOURCE: cast iron pans
Cast iron cookware is NOT recommended due to the weight and the potential damage it can cause to the glass top surface. There's nothing better than a good old-fashioned cast iron skillet that's been broken in over a number of years of use, but they are better suited for gas ranges rather than electric. I hate it. I have several cast iron skillets that I only use on the outdoor grill, because I currently own a glass top electric range.
Aluminum bottom pans and copper bottom pans heat well, but can leave metal transfer marks on the cook top surface. If the marks are cleaned after use with an approved stove top cleaner, you shouldn't have any problem retaining the condition of the glass surface, however. Stainless Steel seems to offer good resistance to metal transfer, but takes a little longer to heat than aluminum or copper. So...you have somewhat of a trade off. Baked enamel cookware seems to be the best recommendation because it heats wells and causes the least amount of damage to your glass top surface.
IMPORTANT: Make sure the bottom of your cookware is FLAT. If your pans are warped or bowed, this can cause uneven heat transfer on the heating elements and potentially cause the cook top to crack. Most manufacturers will not replace the top if it still under warranty if it is determined that your cookware caused the problem.
A little over kill, but I hope this helps you.
SOURCE: CAN I USE ENAMELED CAST IRON POT ON MY NEW GE GLASS TOP RANGE
yes they can just cant slide them around cause of scratching but as far as performance they are fine
After use;
1. Rinse your wok in warm soapy water
and remove any food from the inside surface.
2. If you need to clean the wok more
thoroughly you can do it in hot water but don't use any soap or chemicals.
3. Dry the wok with a towel
4. A properly seasoned wok won't give
off any black smudges. If yours does, it may still be dirty or just need to be
seasoned again.
