The drum area seems to get louder as the drier gets hotter. When you first turn on it runs normally, but after drier gets hot it sounds almost like a grinding noise coming form back of drum area, not squeaky but loud dragging type noise.
SOURCE: squeeky noise
I own a Frigidaire Heavy Duty Dryer The Model # is FDE436RES1. It is 10 years old. When running the dryer it makes a very loud squealing noise although the heat and the dryer still work. Is this a belt or roller problem or does it sound like something else. It is very high pitched and can be heard throughout the entire home. I do not know much about dryer troubleshooting so your help would be greatly appreciated. Thank You.
SOURCE: Frigidaire Dryer making loud thumping noise in back.
Some things to check.
Worn rear drum rollers, idler pulley, or drum front slide kit.
Click here for illustrations.
Hope this helps.
SOURCE: drum making intermittent sqeaky noise for 3-4 minutes then stops
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
ytg
SOURCE: loud squeaking noise coming from back center when drum tumbles
I am having the SAME issue. I try to put up with it, but the sound is horrific!!
FDE216RES2
SOURCE: Frigidaire electric dryer (model # LEQ1442ESO) is
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Hello friend, thanks for your inquiry!
From my understanding your Frigidaire dryer is making a loud noise as it continues to go through the cycles. It could be an issue within the drum not properly being balanced and the load is now rubbing against the wall of your dryer.
It is also possible that the belt is not securing the dryer and it is not properly spinning. I would suggest seeking assistance from a professional to come out and properly diagnose your appliance to avoidany unnecessary part purchases. -Matt
