No Power to Control Center, Line inputs no longer appear in mixer
Creative Audigy 4 Pro: Connector cable became unplugged from the rear of control center, now it has no power to the control center, my 5.1 speaker system works fine and internal (direct) recording is functioning perfectly. In the mixer software the line inputs 1, 2 and 3 no longer appear in the mixer view. Has anyone else experienced this situation?
This download is a driver and sound card applications providing Microsoft® Windows® 7, Windows Vista® and Windows XP support for Creative Sound Blaster® Audigy® series of audio devices.
This download supports the following audio devices only:
Sound Blaster Audigy including Platinum and Platinum eX series
Sound Blaster Audigy 2 including Platinum, Platinum eX, and Value series
Sound Blaster Audigy 2 ZS including Platinum and Platinum Pro series
Sound Blaster Audigy 4 Pro and Sound Blaster Audigy 4
Sound Blaster Audigy 2 ZS Notebook PCMCIA
DO NOT install this driver for Sound Blaster Audigy LS, Sound Blaster Audigy SE, or Sound Blaster Audigy Value.
Included in this download:
Creative Audigy, Audigy 2, and Audigy 4 Driver 6.0.1.1377
If you're using Windows 95/98, you can download this file and update your Sound Blaster 16, Sound Blaster 32, and Sound Blaster AWE drivers. Please refer to the readme file for installation instructions. This new version solves the audio distortion problem that occurred when the Sound Blaster 16Xpress chip was left running overnight.
http://download.cnet.com/sound-blaster-audigy-driverpack/3000-2120_4-10198813.htmlThe driver contains optimized support for Windows 2000/XP operating systems and is designed for use with all current models of Sound Blaster Audigy audio cards (all existing Sound Blaster Audigy Card to SB023x models). Features includes: drivers are WHQL Certified; provides Dolby Digital decoding from external SPDIF Input; speaker settings in Creative Audio Mixer are synchronized with Windows Multimedia setting; new presets and effects added. http://download.cnet.com/creative-sound-blaster-audigy/3000-2120_4-10198811.htmlnThis update is for all Audigy 2 and Audigy 2 ZS series audio cards, which include the Platinum, Platinum eX, Platinum Pro, Digital Audio and Gamer versions. This update is not meant for original Audigy series audio cards. This update contains additional features and fixes to improve the performance of your Creative Sound Blaster Audigy 2 or Audigy 2 ZS series audio card.
on cnet download.com you can find these drivers hope one of these will help
The first thing to do is to swap teh L & R INPUTS to the amplifier. Did the speaker that works change?
If som the problem is with the setting of the mixer deck. If it did not change, then the problem is with your speaker wiring of the dead speaker, the speaker itself, or that side of the amp.
If the working speaker did swap, that means problem is with the mixer. The question then becomes how are you connecting to the mixer. You should be using TRS 1/4 inch connectors or preferably XLR from the MAIN outputs. These are balanced outputs connections.
If the inputs are from one of the mono inputs, the PAN control for that channel will control how much goes to each speaker... If at center, both will get same signal.
There are so many possibilities that I can't evaluate them until you try the test to find if it is problem of the amp or the mixer that I have given you to try.
you can just piggyback the mixers - take the outputs from the mackie mixer (assuming it is NOT a powered mixer) ... those should be line level outputs - send them into a line level input on the digi 002 and then set that channel on the digi 002 and once set, just leave it, and control the mackie channels individually ... should work fine ...
For audio expertise and PA system help with feedback and noise, try our
new DVD "PA Systems for Small Groups" at www.rexark.com
Hi
it will be a little bit long prosses , but lets start after you finished , let me know, if problem is solved or exist,
as you know the best soloution is to have cd that it came with your pc or your sound card.
but i assume you don't have it,
updating the driver ,doesn't mean it always make is better(they are spose to be ) so you had to roll back as soon as you saw the problem. is ok
1- go to windows update ,chose custom , look at left panel to see if windows offer hardware update , is so(your soundcard might be one of them) download them and restar your pc.
if it did not solve ,
first make restoration point on your system restoration(please don't forget)
uninstal driver make sure ther is nothing left from your sound card.
turnoff your pc , disconect the power and open your pc , take the soundcard out , turn on your pc . and turn it off now instal your sound card ,back , start pc , windows should pickup your sound card ,
please let me know if these steps did help ,if not post what was theresult for more assistanse
thanks ,Marco
you don't have to unplug you r pc while it it working. that can unistall your operating system, windows xp, and other softer with errors. I can still solve your problem in one condition. Send you computer's model number Example= emachine t2080, dell 21342, msi 244365. I will help you if i recieve this model number from you. Post the model number this forum and notify me.
When you upgrade to Vista 64 bit, you also need to update and upgrade all drivers to the 64 bit version. Please update the drivers for your Audigy 4 sound devices and your remote should be back in action.
First, let's start with the BX8a. Those are powered speakers (built-in amplifier in each) so, you do not need a pre-amp. What you need to connect them to your computer is a 3.5mm to XLR cable OR a 3.5mm to 1/4" TRS cable, also known as 3.5mm to two 1/4" mono plugs (the back of the BX8a has inputs that accept either type). Cables are available at most any electronics stores. Make sure you buy a long enough cable to run from the back of the computer to where the speakers will be. It sounds that you only have one BX8a which means you'll be listening to only one channel of the stereo output. In any case, make sure before connecting the speaker(s) to the computer that speaker power is off and volume control is at minimum. Connect the 3.5mm cable end to Line Out 1 jack of the X-Fi sound card and either the XLT or TRS ends to the speaker(s) input(s). Play some audio content on your computer, turn on speaker(s) and slowly increase volume to a safe level. Everything should work fine. Let me know how it goes.
Did you change computers and Operating systems? Ifso does it have the same soundcard? are you monitoring with the hardware mixer or with software in the computer?
