https://salter.com > spare-parts > feet
Buy replacement feet for Salter bathroom scales. Shop our extensive range of spare parts here, & get FREE Delivery on orders over £15.
new batteries? or one's that have been sitting around.
they may be low.
what they say to do...
1.
Open the battery compartment on the scale underside.
2.
Remove isolating tab from beneath the battery (if fitted) or insert batteries OBSERVING the polarity signs (+ and -) inside the battery compartment.
3.Close the battery compartment.
4. Select kg, st or lb weight mode by the switch on the
underside of the scale.
5.For use on carpet attach enclosed carpet feet.
6.Position scale on a firm flat surface. next......
INITIALISING YOUR SCALE
1. Press the platform centre and remove your foot.
2.'0.0' will be displayed.
3.The scale will switch off and is now ready for use.
This initialisation process MUST be repeated if the scale is moved. ie battery replacement.
I went to the Salter website and I could not find that model number. Salter Disc Electronic Digital Kitchen Scales White
However, looking at the other models they had there should be a door on the bottom of the scale. It looks like a release tab that you push in then lift up on. Give that a try.
Hold down the g-oz key and the off key at the same time for about 5 sec's
The hour digit will flash
press the ml-floz key to move the hours.
then press the g-oz key again to move to the minutes.
press the ml-floz key again to set the minutes.
press the g-oz key and it moves to setting the cloak to 12h or 24h option.press the g-oz key to set the time.
And your done.
How to open up the Salter 3007 Aquatronic Digital Scale: 1. Look for a hole (covered by a label) on the bottom of the device, not
far from the L-R centre line, and about 1-3/4" from the front. Peel
back the label and use a small cross-head screwdriver to loosen the
screw that can be seen though the hole (needs about one turn, no need to
remove it). Place the scale upright, and rotate the weighing pad
slightly in a clockwise direction. This will disengage the tabs on the
plastic pad which hold it to a metal base, so that it can be lifted off.
2. Remove the six screws recessed around the bottom of the scale.
3. Place the scale upright and gently "snap" apart the top and bottom
shells (catches molded into the left and right ends). Be *** VERY
CAREFUL *** when doing this as the display is held in place on a plastic
bridge by the upper shell. When this is removed the display is loose
except for a flexible plastic printed connector strip (which links it to
the circuit board). It is *** all too easy for this strip to break away
at one end or the other ***.
I had the same problem with my Salter 987 scale. Pull the battery out for about 10 seconds and put it back in. Then push the scale once so it turns on. After the blinking stops, push it once more. The scale will now zero itself. After the scale has zero'd itself it may turn off after a brief moment. It's now ready to use normally.
If you're standing on the scale when it's trying to calibrate to zero, it will assume your weight is zero. Don't stand on the scale after replacing the battery untill you first complete the steps listed above.
