They should have come with the TV. Sometimes they are screwed into the place where they attach the stand to the TV. Sometimes in a small bag with the stand or with the remote.
Testimonial: "lost the bolts. Just moving it from one stand to the original stand and have no bolts."
You remove the high pressure line using a standard imperial open ended spanner on the fitting where the steel HP line attaches to the PS pump unit.. It will most likely be around 5/8". But, if not that size, if you have a decent range of imperial size open ended spanners you should have no problem finding one that fits perfectly. If you don't in your spanner set then slide an adjustable spanner over the fitting, adjust it up to the bolt on the HP line and then remove and measure the size. Buy a spanner that size (the longer the better) and you should have no issue removing the line as long as the bolt head has not been rounded off.
while the owner manual does not specify the length etc of bolts it does show there are 4 of them---look like find thread machine bolt---may be able to buy a few at the hardware sore or Home Depot---if the threads are inside the base take it with you as a guide.
I assume that its Sony KDL-40S2000 model and it needs following size screws to attache its table stand..
PART NUMBER.. 258060201.. SCREW, +PSW M4X12
Available in Part Store.
Hope that info will help you.
Thanks.
