Refrigerators Logo
A
Anonymous Posted on Oct 08, 2014
Where is the location of the freezer defrost timer
I need to replace the defrost timer can't locate it or find instructions
Brett Scovil
Level 1:
New Friend:
  • Contributor 22 Answers
  • Posted on Oct 09, 2014
Brett Scovil
Contributor
Level 1:
New Friend:
Answers
22
Questions
Helped
4616
Points
30
The defrost timer is usually located in the top of the refrigerator compartment or in some older models its located in the base of the unit. Normally you will see a small 3/8" hole in front of the timer that is used to move the defrost timer manually with a regular (flat type) screwdriver.
5 Related Answers
Anonymous
  • 828 Answers
  • Posted on Jun 20, 2008
SOURCE: Defrost timer
http://www.us1internet.com/FRS24XGCW2_141846.htm
The above URL will take you to an exploded view of the controls. Look at number 23 which will be located behind toe plate below door on the left side. That is the defrost timer. Rotate the clutch head screw Clockwise SLOWLY until you hear a loud click. That is the defrost timer starting the defrost. If the unit restarts after 18-22 minutes and defrost does not take place you problem is most likely the defrost thermostat.
Anonymous
  • 473 Answers
  • Posted on Nov 11, 2007
SOURCE: freezer freeze up
Give me the complete model # from the sticker inside the fridge section and I can help.
Woody J Hiatt
  • 306 Answers
  • Posted on Aug 22, 2009
SOURCE: maytag fridge defrost timer location
If this unit has the temp controls in the middle top of the fridge then it is in there.
Anonymous
  • 725 Answers
  • Posted on Aug 25, 2008
SOURCE: defrost timer location
need to know the make and model...
GE are in the top right back
Frigidaire are under the toe plate left and right also in the back by the compressor. cheaper frigdaire are in the middle center top refer... so you see they hide them in a lot of places..
Anonymous
  • Posted on Dec 27, 2008
SOURCE: Maytag PBF 2255 HEW refrigerator defrost timer location?
These look like schematics that might help you.
http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=PBF2255HEW&mfgModelNum=&fkMfgID=1
For Westinghouse fj383 freezer where is the defrost timer located
The defrost timer in a Westinghouse fj383 freezer is typically located at the back of the unit, near the compressor. It may be behind a cover or housing that needs to be removed in order to access the timer. If you're unsure about locating the defrost timer or don't feel comfortable working on your freezer, it's best to consult the user manual or contact a professional technician for assistance.
Jul 16, 2018 • Freezers
Side-by-side, defrost does not work, fridge has high temperature
Thanks for providing your model number! If other people would do the same they could get help to solve their refrigerator or other appliance problem. Try turning the timer dial clockwise slowly with a flat head screw driver. The location of the timer in your model refrigerator is located inside the control panel inside the fresh food section. Click HERE to see part location number 6 That is the defrost timer=> 482493 Defrost Timer Sometimes there is a round hole on the outside of the control panel where you can place the screw driver and sometimes that hose is covered by a plastic plug. Anyway try turning the timer slow clockwise until fans and compressor stop. Leave the refrigerator off for up to 35 minutes and if it does not restart on it's own then simply turn the timer again slowly until it does restart. If the refrigerator defrost while you have forced defrost this way and timer will not restart refrigerator again on it's own then replacing the timer will be the correct part to replace. If turning the timer does not help in getting defrost we will need to remove items in the freezer to a safe location so you can see what is happening behind the rear wall of the freezer. Item location 33 in the photo HERE is the 2323197 Defrost Heater Assembly Testing the defrost heater can be explained in the video above. Part location number 35 is the=> 2321799 Defrost Thermostat You can test this part but I always change if I need to remover the rear panel of the freezer. I just think it is a good idea. I am here should you have questions, Thanks Sea Breeze
1helpful
Freezer is not deforsting
If your model you listed is a TFX27PRBWW it will have a defrost timer located in the fresh food compartment and behind the controls. It's location is 257 in this photo HERE I would like you to turn the timer clockwise slowly until youi hear the compressor and fans stop. This should put the refrigerator into defrost if the defrost heater is still working. Did you hear any crackling or sizzle when place into defrost this way? Wait up to 35 minutes for the timer to come out of defrost and it should restart the refrigerator compressor and fans. If it does not come on automatically then simply turn the timer slowly clockwise again until they do restart. If you need to turn timer again to start refrigerator you will need to replace the timer=> WR9X489 Defrost Timer
If the defrost timer is not the problem then we move to the freezer side, remove the rear panel of freezer and defrost the frost covering the evaporator as in this photo HERE The model TFX27PRBWW takes a=> WR51X10055 Defrost Heater Assembly
and the defrost thermostat=> WR50X122 Defrost Thermostat
The defrost heater is location 230 and the defrost thermostat is location 24 in this photo HERE Instructions in testing these parts are located on the parts pages I listed above. Please let me know if the model number is different than the one above your post so I may help you better, Thanks Sea Breeze
We have a samsung rf266abbp and the freezer is ultra frosty. this just started this week. the unit is about 1 year old. does it need to be defrosted. if so, how?
Hi, if freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model)
Take care
1helpful
2answers
Freezer frosts up and food gets soft
Repair the defrost system, defrost timer,defrost thermostat and defrost heater.
1helpful
Freezer doesnt freeze and red light at top came on
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
thumbs up
Aug 17, 2009 • Freezers
2answers
Freezer is on and just stopped working
Freezer is not cold
1helpful
DOES NOT MAKE ICE
Aug 13, 2009 • Freezers
2helpful
Freezer freeze up
Your model TFX20JRBKWWW uses a defrost timer part number WR9X489 located behind the light shield in the fresh foods compartment. (top back area). Just in case you need to know, the defrost heater is a part number WR51X10101 located behind the back wall of the freezer.
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
