SOURCE: HP OfficeJet 9110 - Receive Fax Error 223
HP Officejet 9100 All-in-One Series - Changing the Fax Baud Rate Parameters
Information
It is possible to lower the transmission speed of the initial handshake of the HP Officejet 9100 to a lower value that may aid in compatibility and resolve 223, 232, and 283 errors. The following steps will walk you through configuring the setting. These are temporary settings. If the unit loses power, the settings need to be reconfigured.
From the front panel:
The screen will read Cfg param val: 26
Screen will read Test -001+
SOURCE: extra blank sheet of paper with each faxed page
Refer to this link this will help you to resolve your issue.
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?rule=20342&lc=en&dlc=en&cc=us&lang=en&product=2512008
SOURCE: hp5510--will fax, bukt when it prints, the sheet is blank.
First print a standalone test page.
Push Setup >> Print reports >> Self Test report.
If the page prints fine. Reinstall the software. It will work !!
Best Of Luck.
SOURCE: I receive 1 page of an incoming fax but then the
Try this...
a) changing the Error Correction Mode (ECM) to OFF
b) disabeling V.34 option
steps for
a) Fax setup -- All faxes -- Error correction -- OFF
b) Fax setup -- All faxes -- V.34 -- disable
I’m happy to help further over the phone at https://www.6ya.com/expert/ron_9356d26241d4cbf7
