SOURCE: help
Hi - You can download the manual from the link underlined in blue below:
uniden Bc72xlt
See page 33 for programming.
Please update the question & let us know if the information given was useful to you - Good Luck!
SOURCE: looking for a BC72XLT handheld scanner manual
This link at the bottom should work. If not go directly to uniden's web site www.uniden.com and there is a place to get all their manuals
http://uniden.com/pdf/BC72XLTom.pdf
SOURCE: how do you reset a Uniden BC72XLT handheld Scanner
To completely clear out all stored frequencies.
1. Turn off the scanner.
2. While holding down 2, 9 and hold turn on the scanner. It takes about three seconds and you will see the word clear.
SOURCE: how to program and delete uniden bearcat scanner 210 XWneed to c
I can't locate information specific to the 210XW, but hopefully this generic Bearcat programming info will help:
1. Press the MANUAL key to advance to the channel that you wish to reprogram.
2. Enter the new frequency, including decimal point.
3. Press the ENTER or E key.
4. Start over with step one to continue programming channels.
SOURCE: How do I program my Uniden BC72XLT race scanner?
1. Press HOLD. Then enter the channel number
where you want to store a frequency, then press
FUNC and PGM. The channel number appears.
2. Use the number keys and to enter the
frequency (including the decimal point) you want
to store.
3. Press E to store the frequency into the channel.
Notes:
• If you entered an invalid frequency in Step 2,
ERROR appears and the scanner beeps three
times. Enter a valid frequency.
• The scanner automatically rounds the entered
number to the nearest valid frequency.
For example, if you enter 151.473 (MHz), your
scanner accepts it as 151.475.
Need the manual for your scanner? You can download/print it here:
http://www.uniden.com/pdf/BC72XLTom.pdf
For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
