SOURCE: Refrigerator not cooling--has thawed/ but top freezer is cooling
Their is a fan that blows the cold air from the freezer to the refrigerator section, on some models. If thsi fan is frozen or bad what you havwe discribed wil bew the result.
SOURCE: the refrigerator isn't getting cold
the refrigerator part isn't getting cold. it was working but now its just room temperature inside. the freezer part works fine.
SOURCE: why does the freezer and refrigerator not getting
It sounds like the overload/relay , attached to the side of the compressor is bad . There are only 2 or 3 wires plugged onto it . This is easily replaceable . If you had gigen the model number , I could have given you the part number . Take it with you , when you go to a parts store ( complete model number ) .
SOURCE: Refrigerator isn't cold but freezer is
sounds like u have a air flow problem , most common problem could be the damper or also called the difuser. it opens and closes to let air into the fresh food side. also if the frz fan motor is not working , then it will also not be able to send air to the fresh food cycle even if the difusser or damper is open. 1st check to see if you hear a fan sound in the frz. if u do then its not a evaporator fan motor problem. if u dont then u may have a bad motor. the motor should be running antytime u hear the compessor running. hope this helps
SOURCE: my refrigerator wont get cold
Always set the controls to their "normal" recommended setting. Changing them will not work. Is there air blowing from the freezer? The freezer fan may not be working. Or if it is, possibly the air flapper could be stuck closed not letting air flow into the refrigerator.
