LG model LDS5811ST
SOURCE: LG dishwasher model lds5811st error
per instructions in other's posts, I removed door panel, but no wires broken, so called LG and local authorized LG repair and they tell me motor sub-assembly needs replacement, cost $160 for parts, $200 for labor, which is making a new dishwasher look attractive.
SOURCE: door hinge adjustment to LG Dishwasher
There is no adjustment to the door hinges. If your hinges are failing they will need to be replaced.
SOURCE: lg - LDS5811ST Dishwasher OE Error Code
hi
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
SOURCE: Replacing LG Dishwasher door gasket/seal with Part # 3920DD3005A
Problem solved - it was not the gasket - it was the vent tube as defined in one of your on-line reported solutions. Thank you!!!
Testimonial: "Contacted numerous resources to try identify LG dishwasher leak problem, including LG. Found solution,vent tube right here on FixYa. Many thanks!!!!"
SOURCE: Repair door springs - LG dishwasher - LD-2040WH.
my lg door keeps on falling done something wrong with door springs ; how do i repair it.
