Hello Where can I buy a replacement drive belt for a Gtech AirRam AR02 cordless vacuum cleaner? Thanks Erik
SOURCE: Belt Replacement in Hoover Savvy
go to thehooverstore site. find your machine and they'll have exploded diagrams for your machine - your should be able to tell how to replace the belt.
SOURCE: Dyson DC07 drive belt replacement
Hi.
The other end of the drive belt the part you cant see goes to a clutch.
The clutch unit has 2 belts one is clutch to motor the second is clutch to brush roller.
You obviously look after your machine because you say you have had no problems with belts or clutch for 5 years.
Both belts & clutch can be worked on but its alot to explain so look at this site for service manuals.
http://dysonmanuals.llc.nu/
SOURCE: hello. I have an electrolux
Hello! There are two solutions to this as the Glider model you speak of could be the more old fashioned type where screws on the bottom foot plate (ie where the spinning brush sits) have to be undone in order to get to the drive belt.
However if you have blue/red/Harmony Glider type model, the drive belt location is on the top of the hood where the floor selector is. There are three screws to undo here; one sits just underneath the main hose to the left hand side of the machine (and can be tricky to take out) if looking at the machine from the front, whilst right at the front of the machine, you'll see two other cross head screws which need to be undone. Make sure that the rotary height dial is out of the way - the top hood should then pop open revealing the brush. Then just take out brush by grabbing the beater bar and pull upwards gently. Take off the old belt, put on a new one around the spindle motor and then onto the beater bar and push the brush roll back in.
Unfortunately you may need brute strength for this as a new belt is often tensioned.
Dont forget to rate. Thanks.
SOURCE: My vacuum cleaner belt keeps burning up as soon as
CHECK ROLLER BRUSH PROBALLY HAS STRING WRAP UP AROUND THE ROLLER OR THE END BEARINGS ARE FROZEN IF SO SRAY WD40 IN BEARINGS TILL THEY FREE UP OR REPLACE ROLLER BRUSH
