SOURCE: Timex Mid Size Sports 1440 WR50M
If your set up is: Top-Left=Indiglo Top-Right=St./Stop Bottom-Left=Mode Bottom-Right=Lap/Reset
Than follow these steps:
1. Press Lap/Reset and hold. You should see the time the alarm was set for.
2. While holding Lap/Reset, press Mode.
3. Let go of all buttons.
4. There you go!
Hope that was a help
SOURCE: Set watch
I have a G Shock DW-004 made in 1997. I had this same problem, and I tried everything to change TO military time and back to standard time. I just read the bit to try and was about to do it. I pressed the top left button to get the time to flash, and hit the light button by accident (the one with the big G on it) and VIOLA! It changed to military time. So in my model, anyway, the G light button (under the display on the edge of the watch body) changed the time to military from standard and back again, when the time is flashing.
SOURCE: need manual for armitron sports watch 40/8172
Go to the Amitron web site , "amitron.com".
Select "support" and the "watch instructions" from the drop down menu.
There will be a number of illustrations
Using the arrow heads on the right, scroll down to the bottom and select the one marked "mens digital".
This file contains the instructions for two manuals, the one you want is the second one (scroll down to reach the 40/8 series).
Testimonial: "Thanks man,just what I needed!Great tip!"
SOURCE: My TGHK watch is stuck in ''Military Time''...
advance the hours. The first time you go through the 24 hour cycle, it will be in am pm mode, the second time in 24 hour mode, the next time in am pm. Just keep advancing the hours until it comes up the correct time
SOURCE: Looking for instructions on a (UNLISTED watch MDL#1070)
You can get the instruction manual here:
http://www.genevawatchgroup.com/pdf/unlisted/UNLISTED-GENERAL-ANALOG-DIGITAL-INST.pdf
